Introduction: Arduino Sensor Gauntlet
Mission: Build a gauntlet with finger pressure sensors through Arduino configuration
Why: Solution to nerve damage in the left hand caused by Ganglion Cyst
What: Loss of feeling in hand/thumb causes a chain reaction of dropping whatever is held in that hand.
How: Arduino programmed with two sensors, one on the thumb and one on the middle finger, feeding back information to a vibration motor in the gauntlet. This should allow for acknowledgment that object is being held in hand successfully instead of resulting in dropping an item.
Step 1: Materials: Arduino Uno
Arduino Uno
Step 2: Materials: Force Sensitve Resistor-Small and Male Connector
Force Sensitive Resistor - Small
https://www.sparkfun.com/products/9673
- Solder to the end of Force Sensitive Sensor to ease assembly
Step 3: Materials: Vibration Motor
Vibration Motor
Step 4: Resistor
Step 5: Breadboarding
Breadboard to see if sensors and Arduino will talk to each other.
- Force Sensitive Sensor
- 3.3V (Green wire in photo) to Force Sensor
- A0 pin (Blue wire in photo) to Force Sensor Pin with 10K resistor
- Ground Wire (blue in photo) to bread board
- Vibration Motor
- Ground (Blue Wire)
- Pin 3 (Red Wire)
- Can be powered by 9V Plug
Step 6: Code
/* FSR simple testing sketch.
Connect one end of FSR to power, the other end to Analog 0.
Then connect one end of a 10K resistor from Analog 0 to ground
int fsrPin = 0; // the FSR and 10K pulldown are connected to a0
int fsrReading; // the analog reading from the FSR resistor divider
int motorpin = 3; //pin for vibration motor
void setup(void){
Serial.begin(9600);
pinMode(motorpin, OUTPUT);
void loop(void) {
fsrReading = analogRead(fsrPin);
Serial.print("Analog reading = ");
Serial.println(fsrReading); // the raw analog reading
int vspeed = map(fsrReading, 0,810, 0, 255)
;analogWrite(motorpin, vspeed);}/*
Step 7: Mobilize the Setup
Step 8: For the Gauntlet
I used leather to make the gauntlet, other materials can be used.
Step 9: Measure
- Create a pattern for hand and forearm.
- Trace on Bristol Board or other firm paper and cut out.
Step 10: Create Design
- Draw desired pattern and tape to leather holding it secure
- Use a tool to trace pattern onto leather and carve/bevel as desired.
- Leather should be damp but not too wet before carving
Step 11: Assemble
- Use cord to tie together
- I used a leather whole punch to create holes
- For a temporary hold, I used electric tape to hold the electronics in place. For a more permanent solution, I plan to leather strips sewn in for the electronics.
- Force sensor is in thumb and vibration sensor is on top of hand
Step 12: Dye
I used leather dye to paint the design, only needed if desired.
Step 13: Test
Test to make sure everything works.
