Arduino for a Wired Home Assistant Network
Introduction: Arduino for a Wired Home Assistant Network
About: I don't know
Wifi components like the various Sonoff, Tasmota and ESP8266 are very easy to configure and use, but things often are not easy as they appear.
In industrial/business environments wireless automation is not so common. Wireless components are less reliable than their wired counterparts.
Would you use a wireless smoke sensor in a factory? I don't think so. And why use a wifi magnetic door sensor in your home?
Wired sensors/actuators are very more reliable, don't need battery, no radio waves in your home.
What i did is an hardware component that can be connected via RS-485 to a home assistant controller (via the Modbus platform). It's based on an arduino. It's similar to the Sonoff switch/relay, but it's wired.
It can act as a light controller (via a relay and an input for the buttons).
It can act as a remote switch (via a relay and an input for the buttons).
It can act as a thermostat.
It can act as a temperature sensor.
A single arduino board can be all these things at the same time, with many input/outputs connected.
Step 1: Build the Hardware Part
You need an arduino board.
I've used an arduino nano but others will be ok.
Connect the Rs-485 converter, a display if you plan to use it, relay(s) and set it up for push buttons.
Step 2: Flash the Firmware
Code can be found at https://github.com/andrea1388/ArduinoModBusHomeAssistant
Don't forget to configure it before copiling. You need to set up the pins used as input, outputs, if it have a Temperature sensor, a display and so on
Step 3: Configure Home Assistant
Edit the configuration.yaml
climate:
- platform: modbus name: Thermostat slave: 1 target_temp_register: 0 current_temp_register: 2 data_count: 2 precision: 1 unit_of_measurement: °C data_type: float
Step 4: Connect the Arduino With the Raspberry Running Home Assistant
Usa a RS-485 USB dongle. You can find it on ebay or amazon. It's very cheap.
Step 5: Restart Home Assistant
Now you can see the temperature set point and control it. Set point can be controlled via automation script and from other components. Using a google assistant you can modify the temperature via vocal commands.
Be the First to Share
    • Puzzles Speed Challenge
    • "Can't Touch This" Family Contest
    • CNC Contest 2020
      CNC Contest 2020
    2 Discussions
    filipe.machado.morais
    excellent project. I'm implying but a question has arisen. coil 16 is set on the switch and I am not able to turn pin 10 on / off. what am I doing wrong?
    This would be a good thing to be part of a smart home automation system.
