Arduinukyah - a Hanukkah Menorah
Introduction: Arduinukyah - a Hanukkah Menorah
A very simple Chanukya (the 8 lights nemorah ) to light one each day of Hanukkah
Made with arduino nano, leds, some resistors and a thermistor to sense the fire and light a led each time you put a flame near
Supplies:
Arduino nano
8 yellow leds
one rgb led for the 'shamas'
one thermistor
8 500 ohms resistors for the LEDS
one 10K resistor for the thermistor
Teacher Notes
Step 1: The Code
The code for the arduino ide:
int candles[] = {2, 3, 4, 5, 6, 7, 8, 12};
//input for the thermistor(temperature sensor) int yom = 0;
void setup() {
Serial.begin(9600);
// Set up pin modes
pinMode(inPin, INPUT);
pinMode(candles[0], OUTPUT);
pinMode(candles[1], OUTPUT);
pinMode(candles[2], OUTPUT);
pinMode(candles[3], OUTPUT);
pinMode(candles[4], OUTPUT);
pinMode(candles[5], OUTPUT);
pinMode(candles[6], OUTPUT);
pinMode(candles[7], OUTPUT);
pinMode(candles[8], OUTPUT);
pinMode(candles[9], OUTPUT);//is pin 12 (we need 9,10 ,11 for analog)
//rgb "shamas" led
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT); \ }
void loop() { i
nt sensorValue = analogRead(A0);
//heat sensing lLED in pin A0
Serial.println(sensorValue);
//change sensor value to adjust sensitivity
if (sensorValue>50){ yom +=1;
delay(1500 );
if(yom>0){
analogWrite(9, random(100,255));
analogWrite(10, random(100,255));
analogWrite(11, random(100,255));
delay(100 ); }
else{
analogWrite(9, 255);
analogWrite(10, 255);
analogWrite(11, 255);
val = digitalRead(inPin);
// read input value for pushbutton
if (val == HIGH) { yom +=1 ; delay(500 );
if(yom > 8){yom=0;}
} i
f(yom>0){
digitalWrite(2, HIGH);
if(yom>1){
digitalWrite(3, HIGH);
if(yom>2){
digitalWrite(4, HIGH);
} i
f(yom>3){
digitalWrite(5, HIGH);
if(yom>4){
digitalWrite(6, HIGH);
if(yom>5){digitalWrite(7, HIGH);
if(yom>6){digitalWrite(8, HIGH);
if(yom>7){
digitalWrite(12, HIGH);
if(yom==0){
digitalWrite(2, LOW);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
digitalWrite(5, LOW);
digitalWrite(6, LOW);
digitalWrite(7, LOW);
digitalWrite(8, LOW);
digitalWrite(12, LOW);
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
