Armattan Japalura 4 Build
About: I'm a UAV player, I attention most news about UAV, And I know much about UAV or UAV accessories, like batteries, cameras, motor and so on
Armattan Japalura is the fanciest micro frame around, and the second design in Armattan’s selection that features aluminum protection. Inspired by many of the same principals as the Chameleon, the Japalura is a lighter, more compact package that still supports many of today’s FPV standards. This “4 inch” frame can handle full-sized miniquad guts, houses your standard HS1177 camera, and shields everything but the lipo battery with two 4mm thick 6061 aluminum ribs.
There are some Japalura Specs from Armattan official site
Frame Weight: 56g
Motor to Motor: 174mm
Frame Shape: Freestyle Bus
Bottom Plate Thickness: 3mm
Other CF Thickness: 1.5mm
Aluminum Parts: Aircraft Grade 6061
Motor Mount Pattern: 13xx
Center Stack Mount Pattern: 30.5mm or 20m
Max Center Stack Height: 28mm
Warrantied Parts: Top-to-bottom (all)
Recommended Components
Motor Sizes: 1407/3500-4000kv
ESCs: 12-20a
Prop Size: 4″
LiPo: 3S-4S/650-850mah
Though Armattan recommend these motors, ESCs and Lipos, but here I choose 30A ESCs and 1300mAh 4S Lipo.
Step 1: Part List
Other than what is listed below, here are a few bench necessities for any build:
Zip tiesBlue loctiteHeatshrink of various sizesParacord 550 (optional)A nylon nut set with 2mm and 1mm spacers
Step 2: Mounting the Flight Controller
It’s best to start by fitting the stack. Sometimes this can be the most time consuming part of the build depending on your stack space and standoff selection. It’s definitely good to have a wide variety of standoffs on hand because the included standoffs rarely ever work. Here I used 7mm anti-vibration standoffs. While most flight controllers work just fine, soft mounted or not, these are less prone to break and could potentially improve flight performance. That being said, they can be troublesome to fit as the female end is more shallow than a typical standoff. I ended up sending a 5mm screw with a 1mm spacer through the bottom plate into the anti-vibration standoffs. Without the spacer the threading is too long.
Step 3: Motors
Next you’ll want to mount the motors. Normally I attach them using two screws at first in the event that I need to remove them for whatever reason. Just don’t forget to finish them up with loctite before the maiden. Once the motors are in place and the flight controller is mounted you’ll want to cut the wires to length. I used 2″ lengths Paracord 550 to protect the wires, but that’s entirely optional.
You’ll want to cut each motor wire to length individually to reach their respective ESC pads. While KISS doesn’t support motor rotation changes via software, you can solder jumper pads to change the rotation as necessary. To cut each wire you need to lay it down flat against the arm, run it up to the standoff, follow the edge of the board and divert straight up into the groove of the ESC pad. It’s important that the wires remain under the flight control board otherwise they’ll get in the way of the canopy mounts.
You’ll also want to solder the XT30 connector to the Lipo input pads of the flight controller. I like a short lead here, so 2-3cm should be sufficient.
Step 4: Receiver
Since KISS doesn’t allow you to test your motor rotation without a bound transmitter, you’ll want to wire up your receiver first. This is fairly straightforward, so just refer to the photos to learn the wire positions. To prepare the FC pads, add a little flux and create a nice shiny pillow of solder. The key is to leave none of the copper pad showing. This is where a quality iron is important. If the solder makes a pointy bit as you pull away you either aren’t operating at a high enough temperature (750 to 800 degrees) or your iron tip lacks sufficient flux.
Now you need to bind your RX and test the motor rotation. First download the latest KISS “CC” FC Firmware and install KissFC to Google Chrome. To update the firmware open KissFC, plug the USB cable into your flight controller, hold the boot button and plug the other end into your computer. While continuing to hold the button choose the firmware you downloaded and flash it. If you let go too early the process will fail.
After the firmware has been updated, attach a lipo, connect to the board and click “Data Output” to test the motor rotation. I normally rub each motor to feel the rotation direction. For any motor that spins the incorrect direction solder the corresponding JP1 jumper for that motor. Refer to the KISS CompactCTRL “CC” Manual for details.
Once you’ve completed these steps you can mount your RX and antennas. What I did was use a couple layers of double sided tape to prevent any potential shorts against the flight controller. Using wide shrink tube would be a better solution, but I had none wide enough for this RX. The antennas are incredibly long, so I rotated the U.fl connectors 180 degrees to send the antennas forward. I wrapped them around the standoffs across to the other side, and out behind the front arms. If you do it just right you’ll manage 2in of zip tie for the tips of both antennas.
Step 5: Canopy and FPV
Now you can assemble the canopy and wire the camera and VTX. Be sure to mount the antenna holder flat side out so the wings of the pigtail catch the lip. This prevents the pigtail from rotating as you attach your antenna. Since we’ll eventually be using TBS Smartaudio, you can solder the audio wire of the VTX to the TX pad of the FC. Now depending on which version of the TBS Unify you’re using (HV or 5V) you’ll either want to solder the power leads to the lipo input pads or the RX 5v/GND pads. Once you’ve done this you can solder the Runcam wires to the VTX wires to complete the wiring. Just be sure to leave enough slack to remove the canopy.
Step 6: Finishing Up!
Now you can attach the canopy being careful not to pinch any motor wires. I found that the pigtail can assert just enough pressure to hold the VTX to the top of the RX, so I didn’t use any tape to hold it down. It seems to fit just right behind the camera, so I don’t believe it’ll be moving around in there. Be sure to loctite your motors and you should be ready to maiden!
    • Faux-Real Contest
      Faux-Real Contest
    • PCB Contest
      PCB Contest
    • Cardboard Challenge
      Cardboard Challenge
    Hello there!
    We're glad you want to share something with the Instructables community!
    And we’re here to help you out.
    Due to some recent changes on the site, we are no longer able to publish stand-alone videos and other forms of incomplete posts. In order to be published live on the site, Instructables must consist of the following things:
    - Multiple steps showing how you made your project
    - Written instructions in each step
    - Your own original images
    Beyond making your Instructable simply publishable, this guide (https://www.instructables.com/id/How-to-Create-a-Feature-Worthy-Instructable/) explains what is required to have your Instructables featured by our site editors. It’s very helpful, and definitely worth checking out.
    We would love to review your project again after you have made the necessary edits, and we will publish your project if it is eligible.
    If you have any questions, please feel free to ask right here or send us an email at service@instructables.com.
    Best,
    Instructables Community Manager
