Introduction: Automated Dishsoap Dispenser With Arduino
This is an arduino based automated Dishsoap dispenser.
We had a leftover pump from a different project so I decided to use it to make an automated soap dispenser. It is very useful and easy to use.
Step 1: The Components You Need
To do this project you will need an HC-SRO4 sensor,an Arduino Uno,a CurieJet pump,a Red and Green LED,and a Female Male Wire Dupont. You might have to 3d print some parts to hold everything together but you don't have to.
These are the files I used:
http://www.thingiverse.com/thing:1276318
Step 2: Where Everything Goes on the Breadboard
When I made this I followed jsvester's instructable here: https://www.instructables.com/id/Simple-Arduino-and...
The schematic can be seen here: https://www.instructables.com/file/F1T3TQ2H994BXMb
The pump needs only +5V and GND to be connected to work, without connecting the yellow wire it's always pumping. The yellow wire is used to turn it on or off (5V means Off and 0V means On) so I connected the yellow wire to the Red LED input.
The code from jsvester is here:
https://codebender.cc/sketch:423932
Step 3: How to Make It Work
After everything was connected I tested it without a pump so I could see if it worked. When it did I used a rubber tube 1.3 mm in diameter and connected it to the pump, than put one end in a cup filled with dishsoap diluted in some water. Please look at the label saying which side is input and which side is output so the pump won't get damaged.
Step 4: The Final Product
This is what it looks like when it is working. If you liked this project please vote for me!:)
