Automatic Night Light(Photoresistor Based)
24
INTRO:
This is a small but working automatic night lamp. It will turn on if there is very less light and will turn on again after 12 hrs. I hope you will like this project and appreciate my work.
Teacher Notes
Step 1: Grab Your Components!
You will need:
1. Arduino UNO x1 (you can use ATtiny85)
2. BC547 x1 (you can use any NPN transistor with higher ratings)
3. Photoresistor x1 (or commonly known as LDR)
4. Relay x1 ( I used 12v but you can use a 5v relay )
5. Piece of prototyping PCB
6. you will need two power supplies one for Arduino and one for the relay
7. 10K Resistor x1
Step 2: Make a Breadboard Prototype
Make a breadboard prototype with the schematic provided
Step 3: Upload the Code!
Upload the code provided into your Arduino. BTW you can use attiny85 instead.
CODE:
int button;
void setup() { pinMode(A0, INPUT); pinMode(6, OUTPUT); pinMode(5, INPUT_PULLUP);
Serial.begin(9600); }
void loop() { button = digitalRead(5); int val = analogRead(A0); Serial.print(val); Serial.println("val"); if (val < 20) { digitalWrite(6, HIGH); delay(43200000); }
Step 4: Make a More Permanent Version!
Solder everything on a piece of prototyping PCB and you are done!
Step 5: DONE!
You just made a nice project!
I will see you at my next instructable!
leave all of your queries in the comment section
