Automatic Night Lights for Outdoors
Introduction: Automatic Night Lights for Outdoors
These Glowstone lights glow during night and switch off during day. They hide in the surroundings and are material friendly. They provide a lot of light and prevent hostile mobs.
Supplies:
3 Glowstone
3 Sticky Piston
4 Redstone Dust
1 Redstone Torch
1 Daylight Sensor
8 Blocks of your choice (I used grass blocks as they fit in the surroundings.)
1 Slab that camouflages with the surroundings (I used Mossy Cobblestone Slab.)
11 Trapdoors
Teacher Notes
Step 1: Step 1: the Slot
A) Dig a pit 3 blocks long, 2 blocks wide and 2 blocks deep.
B) On one 3 blocked side, from the middle block dig a pit 4 blocks long, 1 block wide and 2 blocks deep.
Step 2: Step 2: Glowing in Night
A) On the 3 block side without the 4 block long pit, place 3 pistons facing upwards.
B) Place a Glowstone on each piston.
Step 3: Step 3: Redstone, the Eternal Nemesis
A) Place Redstone Dust next to each piston.
B) In the 4 block pit, place a block at 2nd block from left.
C) At the left side of the block you placed add a Redstone Torch.
Step 4: Step 4: Gaining Senses
A) To the right of the Redstone Torch block place Redstone Dust.
B) In the right corner of the 4 block pit place a Daylight Sensor.
Step 5: Step 5: Keeping Secrets
A) Place a block of your choice over each block except the Glowstone and Daylight Sensor.( I have used grass blocks as they fit in the surroundings.)
B) Place the slab over the Daylight Sensor.( I used Mossy Cobblestone Slab because it fits with grass blocks.
CAUTION!!!: DO NOT PLACE A FULL OR OPAQUE BLOCK OVER THE DAYLIGHT SENSOR AS THE LIGHT CANT PASS THROUGH IT AND THE DEVICE WON'T WORK. ONLY USE SLABS OR CARPETS.
Step 6: Step 6: Finally!!
Place Trapdoors over each Glowstone. When lights will switch off the Trapdoors will remain giving a good frame for them when they switch on.
Step 7: Thank You
You can use these lights in your backyard or wherever you want. Hope you like it!!
Be the First to Share
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    • Wearables Contest
      Wearables Contest
