Automatic Rat Trapper
Introduction: Automatic Rat Trapper
About: STEMpedia is a place bringing project-making tools at one place- kits, online courses, coding platforms, controller app and tons of free learning resources.
Rats! The single most annoying creatures in every household! They nibble away anything and everything that comes their way, destroying precious furniture, clothes, bags; you name it! Only if there was a way to take care of them once and for all! Well, guess what! Your prayers have been answered! With the help of evive, an IR sensor, a computer program, and little DIYing, you can now make a simple yet smart DIY rat trap of your own that no rat can escape! *evil laughter*Put on your sneaky scientist cap and get to work on your mission right away!
Step 1: Things You'll Need:
You can also buy the evive Starter Kit , as the above components and even more, are found in it. Also. there are lots of projects listed on Instructables which are made with the help of it.
Step 2: Assembling the Box
  • Take the base plate, i.e piece A and attach the left wall i.e piece B to it using M3 bolts of 12mm length and M3 nuts.
  • For making Automatic Rat Trapper, you need to have the cutouts of the following dimensions from the cardboard.
    A = 13.5 cm x 9 cm
    B = 14.5 cm x 10 cm
    C = 9 cm x 9 cm
    D = 14.5 cm x 10 cm
    E = 9 cm x 10 cm
    F = 9 cm x 1.5 cm
    Make a slot of the size of the micro servo in piece B.
  • Also, make slots of 0.5 cm thickness leaving 0.5 cm.
  • Next, take the back wall which is piece C and attach it to the left wall and the base using M3 bolts and nuts.
  • Similarly, take the right wall and attach it to the base and back wall using bolts and nuts.
Step 3: Attaching the IR Sensor
Take the IR Sensor and with the help of double-sided tape, attach it to the left wall.
Step 4: Attaching the Servo
  • Now, it’s time to bring the servo in the picture.
  • Take, the servo horn and fix it on top of the servo head using the self-threading screw given in the servo accessories.
    Make sure, that the servo horn is at 0(degree).
  • Now in the slot given on the left wall, attach the servo using M2 bolts of 12mm length and M2 nuts.
Step 5: Completing the Trapper
  • Next, take the upper wall and fix it on the top using M3 bolts and nuts.
  • Now its time to close the trapper.
    For that, take the door and insert it into the gaps of the side walls.
  • Now, to fix this door, we have used a small strip i.e piece G which is glued to the walls.
You can even decorate the trapper if you want.
Step 6: Logic
Here, the servo horn is at 0 degrees, thus holds the door above the ground level.
As soon as the rat gets in the trapper, the IR Sensor detects it's present, and thus the servo rotates at 180 degrees. As soon as it rotates, the support below the door moves and the door closes.
You can again open the door by resetting the servo angle and placing servo horn below the door.
Step 7: Circuitry
Two connections are to be made:
  • Servo Motor:
    It will give support at the base of the door, thus preventing it from closing.
    The motor wires to S1.
  • IR Sensor: Will detect the rat.
    VCC - 5V
    GND - GND
    OUT - Digital Pin 8
Step 8: Arduino Code
To know more about Arduino visit here:
https://thestempedia.com/tutorials/arduino-ide/
Step 9: Scratch Code
The scratch code can also be used in place of the Arduino code.
To know more about Scratch visit here:
Step 10: Conclusion
With this, your rat trap is now ready! The happy days of the pesky little rat are now over.
To explore more projects,
visit: http://thestempedia.com/projects
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    • Maps Challenge
      Maps Challenge
    2 Discussions
    Thorondor95
    Thorondor95
    Question 1 year ago
    Would this actually catch real rats?
    theSTEMpedia
    theSTEMpedia
    Answer 1 year ago
    Absolutely YES! We even experimented on our side and guess what, we caught the one we were looking for.
