Autonomous Hovercraft
162
The objective of this project was to create a hovercraft. For this design, either a singular fan or multiple fans can be used. If the hovercraft is to only be used in water then a singular motor can be used. If the hovercraft is to be used on land then a lift fan will be required.
Supplies:
Step 1: Materials
Battery: https://www.amazon.com/gp/product/B07DNYV4C6/ref=p...
Motors: the motors I chose are no longer available, you will need 2 quad copter motors with ESC and propeller.
Arduino Uno
9V Battery
JB Weld or some other epoxy (will be used to mount components)
You will need access to a 3D Printer
Step 2: Design and Printing
For the design of the hovercraft it was made to generate an air pocket below the hull as opposed to using an air bag. A main flotation system is needed, for this case since i was making something to be used in a pool I used a pool noodle.
I have provided a base thruster mount and rudder that can be used. All of these parts were 3D printed and epoxied together at each others center.
Step 3: Assembling
As mentioned before, all of the components were epoxied together, including the motors. Then the wiring was run to the arduino board.
Step 4: Code
#include  //calls in servo library to allow easy programming
#define echoPin 7 //echo pin for proximity sensor
#define triggerPin 10 // defines pin for receiver of proximity sensor
Servo ESC; // creates a servo variable to allow control of Electronic Speed Controller
Servo Rudder; //creates a servo variablr to allow control of rudder
void setup() {
pinMode(echoPin, INPUT); // sets echopin as input
pinMode(triggerPin, OUTPUT); //sets triggerpin as output
ESC.attach(9,1000,2000); //attaches ESC to pin 9 and sets maximum and minimum pulse times Rudder.attach(8); //attaches rudder to pin 9
Rudder.write(53); //sets rudder position as straight
ESC.write(0); //sets motor speed to 0
void loop() {
digitalWrite(triggerPin, HIGH); //turns trigger pin on
delayMicroseconds(10);
digitalWrite(triggerPin, LOW); //turns trigger pin off
int distance = pulseIn(echoPin,HIGH); // reads input from echopin (distance to wall)
distance=distance/148; //changes distance reading to inches
Serial.print(distance);
// the following if statement says that if the distance read by the proximity // sensor is greater than 10 inches move forward
if (distance > 10){
Rudder.write(53); //rudder is straight
ESC.write(140); //speed set to 125 of 180
delay(1000);
// the following if statement says that if the distance read by the proximity // sensor is less than 10 inches turn to avoid obstacle
if (distance <= 10){
Rudder.write(25); // rudder set to 28 degrees from center
ESC.write(180); // full speed to turn faster
delay(500);
Rudder.write(53);//rudder set to straight after turn
ESC.write(125); // regular speed for going straight
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    • IoT Challenge
      IoT Challenge
    2 Discussions
    ricoebPenolopy Bulnick
    Reply 24 days ago
    I do have a video however the craft had many issues and the video is of it failing. I really liked doing this project so i will release a revision 2 sometime in the summer.
