Avacado-it
Introduction: Avacado-it
This device will help make it possible for those with the ability to use one hand, to cut an avocado.
Teacher Notes
Step 1: Insert Avocado Into Device
Step 2: Close Device and Gradually Insert Pins on Both Sides Slightly
Step 3: Set Device Upright on Hard Surface and Insert Knife Straight Down Against Device
Step 4: Cut Avocado Around the Pit
Step 5: Place Device on Table With Hinges Up and Continue Cut
Step 6: Remove One Pin, Open Device and Flip Avocado
Step 7: Reinsert Pin and Finish the Cut With Hinges Faced Up
Step 8: Press Down As Far As Possible on Both Pins
Step 9: Open Device Remove the Two Halves, Press Down on Half With Pit and Remove the Pit
Step 10: With 2 Halves Still Attached to Pins, Cut Avocado Into Slices Pressing Against Hard Surface
Step 11: Printing Instructions
Download .stl file, print on 3D printer (preferred filament type is PETG), once printed snap hinges together.
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Finish It Already Speed Challenge
