Awesome Mid-Century Modern Cloud LED Lights Project
6,231
61
8
Introduction: Awesome Mid-Century Modern Cloud LED Lights Project
Inspiration: Kitchen Upgrade
We were updating the kitchen in our really cool looking mid-century modern house. Walls were coming down, and the 1962 kitchen designed for a single cook was being transformed into a space where the whole family could participate in meal preparation. The little eat-in area became part of the new kitchen, and the wall separating the kitchen from the dining room was removed. The original lights were fluorescent fixtures that were over 40 years old, and definitely getting replaced. I knew lighting was going to be important. It needed to be bright, with coverage everywhere. I also wanted it to be all LED and dimmable. I wanted something with a Mid-Century Modern vibe and existing fixtures were expensive. Lots of little LED spotlights just weren't going to be the look I wanted. So I started coming up with some ideas. It had to be easy, doable, and above all, it had to be Awesome.
Supplies:
I used the following tools and parts to create the lights:
Circular saw: to cut out the "clouds". I made 7 in total, 3 at 24”x24” with 8 inch LED lights, 3 at 30”x30” with 11” LED lights, and 1 at 36x36 with a 11” LED.
Jigsaw/Reciprocating saw: to round the corners, and cut the opening for the lights.
Drill and counter sink: for the mounting holes.
Sander: to take out the saw marks and soften the edges of the MDF before and after priming.
Small roller brush to paint the primer and finish coat which was a pure white with a flat/matte finish.
Stud finder: to find the ceiling joists for installation.
Lights i found on Amazon:
11 inch: https://smile.amazon.com/gp/product/B07JR24RB9/ref...
8 inch: https://smile.amazon.com/gp/product/B07JQHNZG1/ref...
Teacher Notes
Step 1: ...Continue the “Awesome” Projects.
Years ago my daughter and I updated the mailbox and mailbox post to be “Awesome.” Then we updated the lamp post by the driveway to make it “Awesome.”
Step 2: Finding the Right Design
I searched for inspiration online (mostly Pinterest) for iconic MCM designs, and I came up with some designs. The offset rounded corner square within a rounded corner square kept popping up, and I thought it would look right for a light.
Step 3: Finding the Lights
The search for the lights took me to a bunch of different websites, until I found these lights on Amazon. They were square and came in 8” and 12” sizes and were dimmable, so I order 1 each to play with. I also bought a dimmer that is suitable for LEDs, as the 8” lights were rated at 18 watts, and the 12” lights were 24 watts which is pretty bright for LEDs.
Step 4: Trying the Lights and Making a Prototype
When the lights arrived, I wired them to a plug wire, a dimmer, and turned them on. Wow they were bright; I was glad I had the dimmer. So, I made a prototype. I used a piece of 1/2” plywood I had laying around. I cut out a 24” square and rounded the corners. I painted it the same blue as my Awesome mailbox and Awesome lamp post. Then I hung it to see it in action. It was bright. As I was cutting it out, it felt like it was going to be too big, but once I saw it on the ceiling, it looked small. But the style was right. My wife hated the color.
Step 5: The Final Design and Layout
Once the kitchen was going in, I wanted the lights to be over each of the work areas: Sink, Cooktop, Oven, the prep area by the refrigerator, the door and the peninsula. These were kinda random areas in the kitchen, then an idea hit me... make them CLOUDS!!. I can arrange them sort of random on the ceiling, with different sizes, painted white. My wife agreed to paint the ceiling blue like a sky to highlight the “clouds.” The plywood I used for the prototype had a grain that you could see when painted, so I decided to use MDF.
Step 6: Cutting Out the Parts.
I first cut out the main squares from 1/2” MDF. Then rounded the corners, using a peanut butter jar lid to draw the line.
Then I cut the openings for the LED lights.
Then I ripped some strips of 5/8” thick plywood at 3” wide and different lengths for the different sized MDF clouds, that I had to use to mount the lights to the ceiling.
Sand paper: to take out the saw marks on the edges, and soften the edges of the MDF before and after priming.
Step 7: Installation Day.
I located where I wanted each of the lights to be on the ceiling. For the 12” lights over the sink, the stove top, and the prep area, I wanted the lights to be half over the counter edge so there would not be a big shadow as you stood there. For the smaller 8” smaller lights, I wanted one centered on the entry door and one centered on the oven. I measured where the 5/8” plywood mounting strips should be, and found the studs in the ceiling with a stud finder, and screwed the plywood strips to the studs.
Step 8: Wiring Day
Wiring the lights was a long day for me. I had a permit from the city, and I'm up on the current codes. I suggest you get a licensed electrician to do the final wiring if you are not up on the current codes in your city. I have done lots of electrical work in the past, so I was OK with doing this kind of wiring. I did not want to daisy chain the lights, so I ran a separate #14 AWG (14 Gauge copper) to each light, all tied together in junction boxes in the attic off the dimmer switch.
Step 9: The “Awesome” Results Day
OK... this actually turned out EXACTLY as I had hoped: very bright, all the work areas had plenty of light, and the dimmer can make it not so bright when you don't want to be blinded in the dark nights.
And......my wife says it looks awesome!
Make it Glow Contest
Be the First to Share
    • Sculpting Challenge
      Sculpting Challenge
    • 3D Printed Contest
      3D Printed Contest
    • Motor Vehicle Contest
    8 Discussions
    mvachon70
    mvachon70
    3 months ago
    HI I liked your idea & thought the clouds could be used to hide the holes in drywall when dealing with a two story. Is there three junction boxes because you have 3 switched configuration ? Thank you for sharing.
    Mike
    JTK317
    JTK317
    Reply 3 months ago
    I had the wire from the dimmer switch, and 7 wires (possibly 8) for the lights. Since I could only get 4 wires into a splice (I had lots of red wire connectors), I would need at least 3 pigtails off the switch wire. I thought of using a terminal block of some kind to tie all 9 of the wires together, but never found something suitable, so I just went with multiple junction boxes to make it easy.
    rdy4trvl
    rdy4trvl
    3 months ago
    Very nicely done....very mid-century too! I like that mail box. If you do more mid-century project, I hope you'll share.
    wkparker
    wkparker
    3 months ago
    Very cool - love the design and the various sizes.
    Future idea - add a ring of warm white LED strip between the top of each cloud and the ceiling, wired to a separate circuit - would be great nightlighting.
    JohnC430
    JohnC430
    Question 3 months ago
    Very nice design. how did you route the wires to each lamp?
    abomin
    abomin
    Tip 3 months ago
    Looks nice!
    By the way, I use broken 15.6-inch LCDs from laptops with a removed glass layer. They are dimmable and consume ~ 5 W in the range of 5 ... 30 Volts.
    AnandM54
    AnandM54
    3 months ago
    Really awesome!!!
