BC547 Double Transistor Audio Amplifier
About: Share diy projects to those who have the same hobby with me
Hii friend,
Today I am going to make an amplifier using Double transistor of BC547.
Let's get started,
Teacher Notes
Step 1: Take All Parts As Shown Below
Components required -
(1.) Transistor - BC547 x2
(2.) Resistor - 10K x1
(3.) Aux cable x1
(4.) Power supply - 5V DC
(5.) Capacitor - 63V 1uf/2.2uf x1
(6.) Speaker x1
Step 2: Connect Both Transistors
Firstly we have to connect both transistors.
Solder emmiter pin of transistor-1 to base pin of transistor-2 as solder in the picture.
Step 3: Connect 10K Resistor
Next we have to connect 10K resistor to the circuit.
Solder 10K resistor between collector and base pin of transistor-1 as you can see in the picture.
Step 4: Connect Capacitor
Next solder +ve pin of 2.2uf capacitor to base pin of the transistor-1 as you can see in the picture.
Step 5: Connect Speaker Wire
Connect speaker wire to the circuit.
Solder +ve wire of speaker to collector pin of transistor-1 and
solder -ve wire of speaker to collector pin of transistor-2 as you can see in the picture.
Step 6: Connect Aux Cable
Next solder +ve (Left/Right) wire of aux cable to -ve pin of capacitor and
solder -ve wire of aux cable to emmiter pin of transistor-2 as solder in the picture.
Step 7: Connect Power Supply Wire
Next connect 5V DC Power supply wire to the circuit.
NOTE : We can give input power supply with 5V charger,5V battery,.....5VDC.
Connect +ve clip of power supply to collector pin of transistor-1 and
-ve clip to emmiter pin of transistor-2 as you can see in the picture.
Step 8: Aplifier Is Ready
Now Plug-in aux cable to mobile phone/laptop/tab.....and play songs.
Thank you
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    ErwinM5
    Question 2 months ago
    Fantasties project, and simple
    I would like to try the circuit to control a servo with my android phone via sound would this be possible
    Can you help me please
