BEER, a Trellis for Hops, a Support for Growing Them in Your Backyard.
2,888
33
4
About: relaxed pic
My son-in-law makes his own beer. A couple of years ago he started growing his own Hops, but they needed a support for the plants that grow like vines.
I made a frame that rope is attached to and the other end of the rope attached to their shed. From the elevated rope lines are dropped down to the individual plants to grow up, see pictures.
My daughter asked me to build a couple of more supports because her husband had planted some more and different variety of Hops and she wanted to give him this for a birthday present.
Some information on Hops,
https://en.wikipedia.org/wiki/Hops
Step 1: Material Used Per Stand (Tripod)
6 - 2 x 4 x 10 foot long Pressure Treated
4 - 2 x 6 x 4 foot spruce
2 - 2 x 6 x 16 inches spruce
1 - large tube construction adhesive and a caulking gun for it.
1 - box 3 inch # 8 deck screws (300) this is enough for two tripods.
1 - 12 inch long x 3/8 inch diameter bolt with two washers and two nuts.
1 - 8 inch long x 5/16 inch eye bolt and a washer and two nuts.
Approximately 150 feet of weather and sun resistant rope, I used para cord since I had lots of it. Something to cut it with and a Bic lighter to melt the cut ends.
Note: In Canada and the US, when a dimension states " 2 x 4" it means 2 inches by 4 inches then the next number is the length in feet or sometimes inches which is usually stated in a material list.
Step 2: Construction Step One
I laminated the 2x4's using construction adhesive and deck screws. These are the legs of the tripod each one is made up of two 2 x 4's.
Then I drilled a 7/16's of an inch, hole 3 inches from the end of each tripod leg. This step is only done at one end of the legs.
Take the 12 inch bolt and put one of the washers on it. Then stack the three legs together and put the 12 inch bolt through all of them. Another washer and two of the nuts tighten together near the end of the bolt. This may appear strange, but it needs to be this way so that the legs will be-able to spread out to form the tripod. You can see this in the photo.
On the middle leg drill though one of the 2 x 4's a 7/16" hole and put the eye bolt through it. Install it so that the eye is facing away from the middle leg when it is angled back ( see photo ). Put the washer and two nuts on and tighten the two nuts together to lock them in place.
Step 3: Costruction Step Two
Stand the three legs up, ( this is easier and safer to do if you have a helper), tilt the middle leg out about 3 feet out, then the two outside legs about 3 feet apart so you have the shape of a tripod. This is a lot more stable. Take two of the 2 x 6 x 4 foot stack on edge and put against the two outside legs, I left 5 1/2 inches over lap on each side.
Screw the top board using four screws per leg. The lower board is not fastened it was only there to hold the top board in place.
Take the two 2 x 6 x 16 inches boards stack them on the edge and lay them against the middle leg, attach the top board with four screws.
Now take two of the 2 x 4 x 4 foot and lay across (edge) the outside of the middle leg and the inside of the outside legs. These boards are on top of the outside legs and inside leg that you did in the previous steps. They are attached with three screws per leg end and one screw ( toe nailed ) into the cross piece.
Step 4: Construction Step Three
Now you have a basic tripod.
Now to add cross pieces to add structural support.
The last 2 x 4 x 4 foot is put on the inside of the tripod between the two out side legs, it is fasten in place with three screws per side.
The last 2 x 4 x 16 inches is placed against the inside of the the middle leg it is fasten in place with three screws per side.
You may be wondering why I have numbers or letters on my pieces, I made them at home, dis-assembled them and
took them out to my daughter's house, where her husband and I re- assembled them, where the Hops where planted.
Step 5: Final Construction Step
We assembled the tripods at each end of planted Hops, Kevin ( my son-in law ) tied one end of the rope to one of the eye bolts then strung the rope across the Hops. Then he tied stringers on this main rope, one for each Hop plant using a slip knot so the stringers could be spaced properly. We left about 12 feet of the main rope longer than we needed, this was passed through the other eye bolt, this makes the rope be easily raised or lowered as the season dictates. The rope was then raised up. I put two screws in one leg so that the excess rope could be tied off.
Kevin then wound the vine like Hop plants around their individual stringer ropes.
Birthday present completed.
Step 6: The Original Trellis and How the Hops Grow on It.
The Hops grow very fast.
I did some slight modifications to the new tripods so that they didn't need bags of soil to help stabilize them.
I hope to get some pictures in the Fall when the Hops are about to be picked.
Backyard Contest
This is an entry in the
Backyard Contest
  • Stone Concrete and Cement Contest
  • Beauty Tips Contest
    Beauty Tips Contest
  • Barbeque Challenge
    Barbeque Challenge
4 Discussions
DrunkenNinja
25 days ago
Nice project! As a fellow hop grower I was looking to make something similar. Initially I thought of using old/discarded telegraph poles but it seems that they are hard to come by at an affordable price or a small quantity. Using 2x4 laminated and joined in this way looks like a good solution.
I ended up using two trees to act as the vertical supports to span with 3mm fencing steel wire (2 runs). It will do for this year's growing season but next year I will need something better (and don't want to end up damaging the trees!).
The biggest challenge I see is gaining enough height as some varieties of hops will grow 25-30ft up. My current solution to this is to have the growing strings at an angle so you can have more length without as much height.
john pedersenDrunkenNinja
Reply 25 days ago
Thank you DrunkenNinja, The trees are a good idea, if you have sturdy ones and there is enough open space between them, I like your angled idea as well. The height that they can grow to is an issue, the 10 foot legs are the longest that I could carry safely in my small truck. Thank you again and good luck with your growing.
smartrem
27 days ago
The hardest part is to convince my wife we absolutely need this
john pedersensmartrem
Reply 26 days ago
Thanks for the comment, near a fence or property line could be good lines to use stating it would block a near by building or traffic noise. Where my daughter lives is semi rural with a large lot so there wasn't any issues. Good Luck.
