Back Yard Fun or Hillbilly Slip N Slide
About: Im a chef, im a parent , also im an artist and was the studio assistant for the collage for several years I built haunted houses for 10 years did stage crafting for 6 owned my own carpentry business for 4 ...
Its been a hot one this summer. My daughter wants to play in the sprinklers all the time and it uses a lot of water .Found a old waterbed mattress so i decided to build her a slip an slider. And away we go!!!
Supplies:
Old waterbed mattress
Pool noodles 6 to 8
Siscors
Waterproof tape
Teacher Notes
Step 1: Gather It Up
Im not sure why i had a old waterbed mattress ,but this one had a hole in it.
Step 2: Cut Longways
Step 3: Cut the Side and One End
Step 4: Lay It Out Smooth Side Up
Step 5: Turn the Other Peice Onside Out
This will become the water pool at the end. Or cut it and make a longer slide.
Step 6: Add Noodles
Add some noodles to hold the pool. Tape the slide to the pool. Use other noodles to bumper the the slide so that water runs into the pool.
Step 7: Side Away
Add a hose or sprinkler to the end with the spout . RUN JUMP AND SLIDE.
Want to go faster use a bar of soap rub down the track and its faster then a greased pig!
Backyard Contest
Backyard Contest
Be the First to Share
    • Skateboard Contest
      Skateboard Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
