Backpacking Stoves: How to Choose
About: Hi may name is Jac and i am really into engineering and make a lot of weapons.
When you’re backpacking, do you look forward to a cooked meal at night and hot coffee in the morning? If so, you’ll want to bring a stove. But what kind of stove to bring depends on many factors: How light do you want it to be? How versatile? Do you need a stove that simply boils quickly or do you want one that simmers? How many people are you cooking for? Are you going to be traveling internationally and what type of fuel will be available to you?
When deciding how to choose the best backpacking stove for you, the following decision points will help you choose: Stove type: Backpacking stoves are loosely categorised by the type of fuel they use and how the fuel is stored. Stove specs and features: Burn time, average boil time, weight and convenience features may help you narrow your choices. Stove usage tips: Understanding some of the nuances of how a stove works will ensure that you’re making an informed decision and also getting the best out of your purchase when you’re out in the field.
Teacher Notes
Step 1: Types of Backpacking Stoves
There are three main categories of backpacking stoves:
Canister stoves: These easy-to-use, low-maintenance stoves typically screw onto the threaded tops of self-sealing fuel canisters that contain two pressurised gases: isobutane and propane.Liquid fuel stoves: These versatile stoves connect to refillable fuel bottles. While most liquid-fuel stoves run on white gas, you do have other options available, which can be a particular benefit if you’re traveling internationally. Alternative-fuel stoves: This growing category includes stoves that run on fuel pellets or wood.
Step 2: Canister Stoves
Top cooker
Ultralight BRS Cooker (25g)
Canister stoves are easy to use and low-maintenance.They screw onto the threaded tops of closed fuel canisters that contain two pressurised gases: isobutane and propane. Some of these stoves are incredibly small, fold up compactly and weigh only a few ounces. They may be usable in some international destinations that cater to American trekkers.
Pros: They’re small and lightweight.They’re quick to light. No priming is necessary before lighting a canister stove. Simply turn the valve and light with a match, lighter or piezo-igniter.The flame adjusts easily and simmers well (most models).The canister self-seals when you unscrew the stove, so there’s no worry about spills and leaks.Some canister stoves have a built-in pressure regulator to provide consistent heat output throughout the life of the canister. This improves cold weather and high-elevation performance, too.
Cons: Their arms may not be long enough to hold large pots securely.It’s tough to know how much gas is left inside the closed canister, so you may want to carry an extra to be sure you don’t run out. (A small 4-ounce canister makes a good backup.)A windscreen should not be used with an on-canister stove because it can trap excessive heat and lead to fuel exploding.In cold weather, canisters can depressurize and produce a weak flame (unless the stove has a pressure regulator)Compared to liquid-fuel stoves, the cost of fuel is greater.Canister waste: Empty canisters need to be disposed of properly; you’ll want to research recycling options near you.
Step 3: ​Liquid-fuel Stoves
Top Cooker
Mini Titanium Alcohol Stove
All liquid-fuel stoves run on white gas, which is highly refined to have few or no impurities. It burns hot and clean, performs well in below-freezing temperatures and, compared to the per-ounce cost of canister fuel, is much less expensive. Some multi-fuel stoves can also run on some or all of the following: unleaded auto gasoline, kerosene, jet fuel or diesel. Fuel versatility makes multi-fuel stoves a great choice for international travelers who face limited fuel choices outside the U.S. (Note: Except for emergencies, REI doesn’t recommend the use of unleaded auto gas from a gas station pump because of gasoline additives that can damage your stove.) There are two main downsides to liquid-fuel stoves: Most require priming, which involves igniting a few drips of fuel in a cup below the burner, creating a small flame that preheats the fuel line. This enables the stove to convert liquid fuel into a vapor. You will need to pump your fuel bottle, too, to increase pressure. They also require periodic maintenance, such as cleaning the fuel hose or replacing O-rings (in the stove and on fuel bottles). There may be many little parts and pieces to keep track of.
Pros Liquid-fuel stoves tend to be low-profile and offer greater stability on uneven ground.It’s easy to tell how much fuel you have left by peering into the fuel bottle.While you do have to buy a fuel bottle, there’s no canister to discard.These stoves perform better than other options at high elevations and in cold temperatures.Cons: Priming and maintenance are required.Fuel spills are possible.They tend to be heavier than canister stoves.Multi-fuel stoves can cost a bit more.Fuels other than white gas have more impurities that may, over time, clog stove parts such as the fuel tube.
Step 4: ​Alternative-fuel Stoves
Flameless Cooker (730g)
These stoves can be good choices for long-distance backpacking and also for home emergency kits. Some are ultralight; others are a bit heavier. There are a few different kinds:
Wood-burning Stoves Because these burn twigs and leaves you gather in the backcountry, you carry no fuel, a nice option for longer or lighter trips.
Pros: These can be simple and lightweight, such as a titanium base-and-windscreen/pot-support setup that folds flat.Some models can generate enough electricity while burning twigs to charge a mobile phone or other small gadget via a USB connection.Some models can be outfitted with an optional grill.
Cons: Finding dry fuel during wet weather can be challenging.Use may be prohibited during a burn ban or in some places at high elevation (for example, Yosemite prohibits twig-burning stoves above 9,600 feet).
Denatured Alcohol Stoves These stoves appeal most to ultralight backpackers because they weigh only an ounce or two. In addition, you only need to carry a bottle of alcohol sized to meet your trip needs.
Pros: Denatured alcohol stoves have few parts that would require maintenance.Denatured alcohol is inexpensive and relatively easy to find across the U.S.The fuel burns silently.
Cons: Alcohol does not burn as hot as canister fuel or white gas, so it takes longer to boil water and requires more fuel.A windscreen is often a must.Denatured alcohol can be hard to find outside the U.S.
Solid-fuel Tablet Stoves These are also a popular choice with ultralight backpackers. Some models are so small they fold up and fit in your pocket.
Pros: InexpensiveLow weight: a pocket-size model may weigh 3.25 ounces; a stove/pot combo, 7 ounces.Compact sizeTablets light easily and may be extinguished and reused later.
Cons: They are slow to bring water to a boil Tablets may have an odor Tablets may leave a greasy residue on the pot’s underside.
Step 5: ​Backpacking Stove Specs and Features
Below are a few of the other key decision points that will factor into your choice for the best backpacking stove for you.
Stove weight: If you’re counting ounces on a long, solo thru-hike, your choice will differ from someone who mainly enjoys weekend backpacking with friends.
Burn time: When looking at your choices, you can compare how long a stove burns using a given amount of fuel.
Average boil time: This spec can help you choose between models, especially if fuel-efficiency is a priority for you. Some general boiling and simmering guidance
Integrated canister systems boil water fastest while also using minimal fuel. Simmering may be possible, but it’s an afterthought in their designs.
Canister stoves boil water quickly, and some models are good to excellent at simmering—great for camp gourmets.
Liquid-fuel stoves boil water very quickly, even in cold weather. Simmering ability varies widely by model.
Alternate-fuel stoves are intended primarily for boiling, though they are slower, sometimes by minutes.
Piezo-igniter: This is a push-button spark producer found on some canister-fuel stoves. It's a handy feature, especially if your matches are lost or wet.
Stabilisers: Sometimes sold separately, stabilisers can be attached to the bottom of fuel canisters to reduce the chance of upright models tipping over.
    • Make It Fly Challenge
    • Stone Concrete and Cement Contest
    • Indoor Lighting Contest
    Swansong
    1 year ago
    Hello there!
    We're glad you want to share something with the Instructables community! And we’re here to help you out. In order to be published live on the site, Instructables must consist of the following things:
    - Multiple steps showing how you made your project
    - Written instructions in each step
    - Your own original images
    Beyond making your Instructable simply publishable, this guide (https://www.instructables.com/id/How-to-Create-a-Feature-Worthy-Instructable/) explains what is required to have your Instructables featured by our site editors. It’s very helpful and definitely worth checking out.
    We would love to review your project again after you have made the necessary edits, and we will publish your project if it is eligible.If you have any questions, please feel free to ask right here or send us an email at service@instructables.com.
    Best,
    Instructables Community Manager
