Bag for Containers
1,820
24
Introduction: Bag for Containers
About: I wb in Belgorod Russia. In 2002 I graduated from Belgorod STU mechanical engineering and CAD. In 2004 I'v defended the dissertation "CAD for ball mill". I am a lecturer in BSTU. My hobby is 3D and...
It is widespread situation – we have got some small parts but do not know where to put them. What parts? Completely different! Bolts, nuts, springs, washers ... made of metal, plastic, wood ... But there are a lot of already exist containers around us: used plastic storages for a food packaging have enough hardness, inner space and covers. We need only arrange these storages into convenient form. I suggest to use simple portable shelve made of one piece of cardboard. See on photos. So far, I use my construction to store mechanical parts now. But in near future I plan to pick berries of different kinds with help of this portable shelve. Certainly the shape and the size of cells for containers depend on your actual resources. So I think you could easy transform construction accordingly.
Teacher Notes
Step 1: Tools and Materials
- cardboard sheet (900x260 mm, t=2 mm, two layers);
- rulers (school size (0.3 m) and long (0.5...1 m));
- pencil;
- paper knife;
- awl;
- scissors;
- cardboard bender;
- old wooden surface as base for cutting operations;
- technical drawing (see next step);
- 4 plastic containers ( ~ L x W x H: 93 x 64 x 90 mm).
Step 2: General Construction
Our storage will consist of one part only. You can download appropriate drawing from the next locations: variant 1 (google drive), variant 2 (yandex drive). Dimensions 64 and 93 determined by the size of plastic containers.
Step 3: Transferring Drawing to a Cardboard
Step 4: Cut Part Out of Cardboard
Step 5: 'First Blade' Bending
To execute all bend operations we will use special tool – Cardboard Bender according the following sequence: 1) Put the cardboard part on the wooden work base; 2) Draw path on the cardboard surface; 3) Move the Bender's Roller along the path with appropriate pressure to reduce the thickness of cardboard plate in a contact area; 4) Bend part along the 'compressed' path.
Step 6: 'Second Blade' Bending
Step 7: 'Third Blade' Bending
Step 8: 'Fourth Blade' Bending
Step 9: 'First Inner Side' Bending
Step 10: 'Second Inner Side' Bending
Step 11: 'First Bottom Side' Bending
Step 12: 'Second Bottom Side' Bending
Step 13: 'First Lateral Side' Bending
Step 14: 'Second Lateral Side' Bending
Step 15: End of Assembly
Step 16: Usage (example)
Organization Contest
Be the First to Share
    • Fandom Contest
      Fandom Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Backyard Contest
      Backyard Contest
    3 Discussions
    MsRockford
    MsRockford
    Question 1 year ago
    What are the units on the measurements? Inches? Centimeters?
    nml235l
    nml235l
    Answer 1 year ago
    All dimensions are in millimeters. Holes for containers may have a size according your containers (see descriptions for 'step 2')
    AnandM54
    AnandM54
    1 year ago
    Nice idea ..
