Ball Balancing PID System
97,483
780
197
About: Hi, I'm Johan Link, a 18 years old student living in Switzerland. I love robotics, computers, 3D printing, photography and skate.
This system holds a ball in balance on a plate. A webcam films the system and a python program analyzes the images to find the position of the ball. The python program calculates the tilting of the tray to prevent the ball from falling.
A proportional-integral-derivative (PID) regulator is used to compensate the movements of the ball. The position and speed of the ball are measured by the camera and these measurements are used by the PID regulator in the python program.
Sorry about the English faults, it’s not my mother tongue.
Step 1: PCB
PCB manufacturing
I drew the pcb with eagle then PCBWay.com manufactured it.
PCB assembly :
I soldered all smd components without paste flux. I don't recommend you to do like me. Instead, follow this tutorial to solder smd components: https://www.instructables.com/id/SMD-Hand-Soldering/
The PCB is powered with a 5-6v 2A power supply.
PCB components :
Role of the PCB
The PCB communicates with the computer continuously. This PCB serves only to control the servomotors.
Step 2: 3D Printing
Warning : inferieur.stl, superieur.stl and plateau.stl files are not 3D printable. inferieur.stl and superieur.stl are made of acrylic. You can use a CNC to make these parts, but you can also cut them yourself in an acrylic sheet because these parts don't have a very complicated design. plateau.stl can be cut in cardboard.
Step 3: Parts Assembly
Step 4: PCB Programming
The PCB contains the same microcontroller as the arduino leonardo. Therefore it can be programmed with Arduino software. The code can be downloaded here.
Before programming the PCB, you have to burn the bootloader: Arduino as ISP and Arduino Bootloaders
Burning the Bootloader
  1. You need an Arduino
  2. Upload the ArduinoISP sketch (arduino software / Examples / ArduinoISP) onto your Arduino board
  3. Make the connections as in the picture
  4. Select "Arduino Leonardo" from the Tools > Board menu.
  5. Select "Arduino as ISP" from Tools > Programmer
  6. Run Tools > Burn Bootloader
  7. The process can take several minutes.
  8. Disconnect all cables.
After this step you have to connect the pcb to the computer with a USB cable and upload this code.
Step 5: Python Program
The most important code is in the computer that controls the system. You can find the code here.
How does it work. The first step is to find the position of the ball. The camera sends the computer live video. The python program receives the video and has to process it. I use the OpenCV library to do the image processing. The program detects the ball thanks to its color. Here the ball is orange, the program will then average the position of all the orange pixels of the image to find the position of the ball. With OpenCV all this is quite simple. I recommend this tutorial for color recognition with OpenCV: https://www.pyimagesearch.com/2015/09/14/ball-tracking-with-opencv/
Now that we have the ball position we can calculate the inclination of the board with PID (proportional, integral, and derivative) control. The regulation is done in three stages. The first step is the simplest. Imagine that we want to stabilize the ball in the center of the board. The further away the ball is from the center, the more it will be necessary to tilt the board. Then you have to measure the speed of the ball: the faster the ball moves away from the center, the more you have to tilt the board.
Step 6: Conclusion
Thanks for reading! If you have any questions, do not hesitate to write a comment.
You can also vote for me in the PCB contest.
PCB Contest
First Prize in the
PCB Contest
    • Beauty Tips Contest
      Beauty Tips Contest
    • Stone Concrete and Cement Contest
    • Sensors Contest
      Sensors Contest
    197 Discussions
    maazmaazmaazsup
    1 day ago
    I am hoping to submit this project as my semester project . Loved your work Johan , Really is something . Looking forward to consulting you when help is needed .
    Loved it .
    hongwongi944
    15 days ago
    How do I set up when I buy at PCBway? For example, Layers, FR4-TG, Thickness, Min Track/Spacing, Min Hole Size, Surface Finish, Via Process, Finished Copper
    Nnkye
    Question 5 weeks ago
    So may I ask, what is the objective of this proyect? Or your own objective if you have any
    anagabriellanc
    Hi!
    i really like your proyect, in Fact i like it so much that I wish to construct it. My question is, for this proyect to work Do i have to use the same USB Webcam that you used? If so then I might have a problem, because I don't think i can buy it online and I don't think there are any places here in my country that sell that same one.
    That was my question, Sorry if I had english faults english is not my first language.
    Thanks!
    1 answer
    eabbasov
    6 weeks ago
    Hi Johan,Thank you for the beautiful project. I made this model for my museum. Works fine.One issue is that although I am using the same camera setup image is not rectified and the blue circle goes outside the camera image
    Algorithm sees the boundaries of the red platform as bigger than it is and because of that the balancing is not very well
    Can you tell me how I can fix these?
    Johan Linkeabbasov
    Reply 6 weeks ago
    Awesome! Thank you so much for the pictures! I love it!
    eabbasovJohan Link
    Reply 6 weeks ago
    John, İs the view on screen looks normal?
    Johan Linkeabbasov
    Reply 6 weeks ago
    It doesn't look normal ? Did you change anything in the code?
    eabbasovJohan Link
    Reply 6 weeks ago
    Haven't changed anything related to this. The issue I am facing is about the boundaries of the blue circle, it falls outside the camera image.
    Did you change the resolution of the camera? I am using the same camera as you have, and also using Windows 10
    Johan Linkeabbasov
    Reply 6 weeks ago
    It is a strange problem. The blue circles are correctly positioned and they have the right size. The program python changes the resolution of the camera on lines 22 and 23. Which version of OpenCV do you use?
    Johan Linkeabbasov
    Reply 6 weeks ago
    Try to remove line 396 of the code python. (img = img[0:int(camHeight),int((camWidth-camHeight)/2):int(camWidth-((camWidth-camHeight)/2))])
    eabbasoveabbasov
    Reply 5 weeks ago
    Result whith :
    camHeight = 480
    camWidght = 1280
    Here the size turned out to big, until it reached a normal rezult.
    HergiE
    6 weeks ago
    hello there! if it is possible to give me your number so I can speak directly via whatspp because I need to submit this project tomorrow!
