Barking Christmas Tree Topper
Introduction: Barking Christmas Tree Topper
About: I am an author and a maker. My current project is Santa's Shop. I'm working on a science fiction type book--more later. @EngineerRigsby
When you walk by, this dog topper flaps his ears and barks!
We had to "borrow" a neighbor's dog, Juston, and work a while to get some "tree topper worthy" barks.
Teacher Notes
Step 1: Parts Needed
The parts list includes:
Arduino Uno
Adafruit Sound Board
Adafruit PIR sensor
8 ohm speaker
6 volt, 2 amp dc power supply
(2) mini servo motors
(2) servo extender cables (24 inches long)
3d printed components
Step 2:
The head was formed in polymer clay (by my wife, Annelle), then scanned, modified and 3d printed.
Step 3:
First, thread the wires up through the hole in the neck. The mini servo motor holders (with servo motors mounted) are put in place by melting (using a soldering iron) to the head.
Step 4:
An extender is attached to the servo horn.
Step 5:
Bearing brackets are melted onto the dog head. 2-56 x 1 1/4" screws are used as the axle rod.
Step 6:
Bearing pieces are melted onto the ears.
Step 7:
Before painting, an assembled ear looks like this.
Step 8:
After a trip to the artist's paint shop, the head with unattached ears looks like this.
Step 9:
A box to hold the electronics is composed of a base, top and two hollow elves. The elves are attached to the box by melting (or with glue). I installed leds inside the elves, just so that I would know if power was applied to the electronics.
Step 10:
Before closing it up, load the sketch into the Arduino and load the .wav (bark) file into the Adafruit sound board (see the Adafruit site for detailed instructions).
Step 11:
Assembled, on the ground, the system is ready for installation.
Step 12:
The box is placed on the back side of the tree. I used green wire and metal duct tape to secure the box to the tree.
Step 13:
The PIR sensor (motion detector) is placed where I want to pick up passers by. The speaker is placed at the base of the tree.
Step 14:
For an active, different tree topper, add a little "bark" to your tree!
Make it Move Contest
Be the First to Share
    • Trash to Treasure Contest
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
