Basics: Join Plastic - #2 Tubing
About: always had a deep connection with junk. drawn to it, magically, from childhood on. spent the nights as a boy roaming the streets and looking for trash to take back home. spent # 2 most of my allowance on the...
, this shows how you can turn a sheet of plastic in some kind of tube.
(ps, see also https://www.instructables.com/id/Basics-Join-Plast... ) ,
Step 1: Material and Tools:
, any kind of flexible plastic works. to demonstrate the technique i pulled a milk-bottle out of the trash.
tools:
__ anything to cut the plastic with (here a pocket-knife)
__ a source of heat and an object to transfer the heat with (here: a soldering-iron.... but if you are out in the wild etc: a campfire and some metal-object like a nail, fork, wire, kinfe etc etc works too),
Step 2: Gut (get) Some Plastic:
,here i cut out the even ´belly´ of a no.2 plastic bottle,
Step 3: Unbottled:
,for mere demonstration i keep it simple: this piece will do. (but, obviously, you can use any size of plastic, from any source, as long as you can bend it easily... see next step:),
Step 4: Roll It Up:
,whatever diameter you wish: roll the sheet up into
(the more layers/windings you got the better for the next step:),
Step 5: Weld It:
,carefully trace a soldering-iron lenght-wise along the tube.
you wanna burn in a seam without actually cutting through to the very inside, thus through, the tube. (see above: the more ´meat´ you got to h/eat into: the easier & stronger. example: lets say you have 6 windings in total, burn down to about the half)
if you do a clean weld/seam the resulting tube will be water-proof,
Step 6: Done
, i post this basic technique here because in future projects i will come back to it as a component. i like modular approaches.
if you have and questions or critique etc: more than welcome.
thank you all.
bow,
    • Stone Concrete and Cement Contest
    • Growing Beyond Earth Maker Contest
    • Barbeque Challenge
      Barbeque Challenge
