Basilica Di Sant'Apollinare in Classe
52
1 Teacher Note
About: I'm primary school teacher in a rural area for more than 25 years
A step by step tutorial on the creation of a 80mm long, 50mm wide and 30mm high model of the Basilica Di Sant'Apollinare in Classe in Ravenna - Italy. This is the first step of the interdisciplinary project "The evolution of the religious buildings architecture" which combines science, history, geography, maths, STEAM education and Digital Literacy education. For more about the project read the teachers' notes.
Supplies:
  • A Tinkercad account.
  • A 3d printer (optionally)
1 Teacher Note
Step 1: Introduction
Watch the videos to see the completed model and a timelaple of the step by step tutorial which follows. The whole idea of a model creation is very simple.
  • Drag a shape into workpale
    • Arrange the properties and
    • put it in the right place
so as step by step to build the model
Step 2: Creation of the Narthex: Step 1
Drag a Box in the Workplane
Step 3: Creation of the Narthex: Step 2
Adjust the length and width to match the scale you have decided and according to your research.
Step 4: Creation of the Narthex: Step 3
Adjust the height to match the scale you have decided and according to your research.
Step 5: Creation of the Narthex: Step 4 - Adding the Roof
Drag a Wedge into the Workplane
Step 6: Creation of the Narthex: Step 5 - Adding the Roof
Turn the Wedge by 180 degrees
Step 7: Creation of the Narthex: Step 6 - Adding the Roof
Adjust the length and width to match the scale you have decided.
Step 8: Creation of the Narthex: Step 7 - Adding the Roof
Adjust the height to match the scale you have decided.
Step 9: Creation of the Narthex: Step 8 - Adding the Roof
Lift it at the height of the box (at 7.50 at this tutorial)
Step 10: Creation of the Narthex: Step 9 - Adding the Roof
Click on both shapes to choose them and align them using the relative tool (as it's demonstrate on the image)
Step 11: Creating the Nave: Main Aisle - Step 1
Drag one more Box into the Workplane
Step 12: Creating the Nave: Main Aisle - Step 2
Step 13: Creating the Nave: Main Aisle - Step 3
Step 14: Creating the Nave: Main Aisle - Step 4: Adding the Roof
Drag a Roof into workplane
Step 15: Creating the Nave: Main Aisle - Step 5: Adding the Roof
Step 16: Creating the Nave: Main Aisle - Step 6: Adding the Roof
Step 17: Creating the Nave: Main Aisle - Step 7: Adding the Roof
Lift it at the height of the Box(at 20.70 at this tutorial)
Step 18: Creating the Nave: Main Aisle - Step 8: Adding the Roof
Step 19: Connect the Created Parts: Step 1
Click on both parts namely the Narthex and the Main Aisle to choose them and align them using the relative tool (as it's demonstrate on the image)
Step 20: Connect the Created Parts: Step 2
Drag the Main Aisle to Narthex so as to "stick" on it!
Step 21: Creating the Nave: Left Aisle - Step 1
Drag a Box in the workplane
Step 22: Creating the Nave: Left Aisle - Step 2
Step 23: Creating the Nave: Left Aisle - Step 3
Step 24: Creating the Nave: Left Aisle - Step 4: Adding the Roof
Drag a Wedge into workplane
Step 25: Creating the Nave: Left Aisle - Step 5: Adding the Roof
Turn the Wedge by 90 or -90 degrees (if necessary)
Step 26: Creating the Nave: Left Aisle - Step 6: Adding the Roof
Step 27: Creating the Nave: Left Aisle - Step 7: Adding the Roof
Step 28: Creating the Nave: Left Aisle - Step 8: Adding the Roof
Lift it at the height of the Box(at 10.58 at this tutorial)
Step 29: Creating the Nave: Left Aisle - Step 9: Adding the Roof
Click on both shapes namely the Roof and the Box to choose them and align them using the relative tool (as it's demonstrate on the image)
Step 30: Creating the Nave: Left Aisle - Step 10: Adding the Roof
Click on both shapes namely the Roof and the Box to choose them and group them using the relative tool (as it's demonstrate on the image)
Step 31: Connect the Created Parts: Step 1
Click on both parts namely the Left Aisle and the Main Aisle to choose them and align them using the relative tool (as it's demonstrate on the image)
Step 32: Connect the Created Parts: Step 2
Drag the Left Aisle to the Main Aisle so as to "stick" on it!
Step 33: Creating the Nave: Right Aisle - Step 1
Click on the Left Aisle and duplicate it using the relative tool (as it's demonstrate on the image)
Step 34: Creating the Nave: Right Aisle - Step 2
Drag the shape outside of the main building and turn it by 180 degrees
Step 35: Connect the Created Parts
Click on both parts namely the Right Aisle and the Narthex to choose them and align them using the relative tool (as it's demonstrate on the image- if it's necessary do the same with the Main Aisle)
Step 36: Creatining the Part Next to Narthex: Step 1
Drag a Box into the Workplane
Step 37: Creatining the Part Next to Narthex: Step 2
Step 38: Creatining the Part Next to Narthex: Step 3
Step 39: Creatining the Part Next to Narthex: Step 4 - Adding the Roof
Step 40: Creatining the Part Next to Narthex: Step 5 - Adding the Roof
Step 41: Creatining the Part Next to Narthex: Step 6 - Adding the Roof
Step 42: Creatining the Part Next to Narthex: Step 7 - Adding the Roof
Lift it at the height of the Box(at 13.58 at this tutorial)
Step 43: Creatining the Part Next to Narthex: Step 8 - Adding the Roof
Click on both parts namely the Box and the Roof to choose them and align them using the relative tool (as it's demonstrate on the image)
Step 44: Creatining the Part Next to Narthex: Step 9 - Adding the Roof
Click on both parts namely the Box and the Roof to choose them and group them using the relative tool (as it's demonstrate on the image)
Step 45: Connect the Created Parts: Step 1
Click on both parts namely the Part next to Narthex and the Narthex to choose them and align them using the relative tool (as it's demonstrate on the image)
Step 46: Connect the Created Parts: Step 2
Drag the Part to "stick" it next to Narthex
Step 47: Creating the Semicylinder Part of the Sanctuary: Step 1
Turn the Workplane in the way to see the back side of the model and drag a Cylinder on it
Step 48: Creating the Semicylinder Part of the Sanctuary: Step 2
Step 49: Creating the Semicylinder Part of the Sanctuary: Step 3
Step 50: Creating the Semicylinder Part of the Sanctuary: Step 4 - Adding the Roof
Drag a Cone into Workplane
Step 51: Creating the Semicylinder Part of the Sanctuary: Step 5 - Adding the Roof
Step 52: Creating the Semicylinder Part of the Sanctuary: Step 6 - Adding the Roof
Adjust the heigth to match the scale you have decided.
Step 53: Creating the Semicylinder Part of the Sanctuary: Step 7 - Adding the Roof
Lift the Cone at the height of the Cylinder(at 13.58 at this tutorial)
Step 54: Creating the Semicylinder Part of the Sanctuary: Step 8 - Adding the Roof
Click on both shapes (the Cone and the Cylinder) to choose them and align them using the relative tool (as it's demonstrate on the image)
Step 55: Creating the Semicylinder Part of the Sanctuary: Step 9 - Adding the Roof
Click on both shapes (the Cone and the Cylinder) to choose them and group them using the relative tool (as it's demonstrate on the image)
Step 56: Connect the Created Parts: Step 1
Click on both shapes namely the Cylinder and the Main Aisle to choose them and align them using the relative tool (as it's demonstrate on the image)
Step 57: Connect the Created Parts: Step 2
Drag the Cylinder to the Main Aisle so as to "stick" on it and to be visible just the half of it (as it's demonstrate on the following step)
Step 58: Connect the Created Parts: Step 2
This is how your model should looks like
Step 59: Creating the Small Chapel Behing the Right Aisle: Step 1
Drag a Box in the Workplane and adjust the length and width to match the scale you have decided.
Step 60: Creating the Small Chapel Behing the Right Aisle: Step 2
Step 61: Creating the Small Chapel Behing the Right Aisle: Step 3 - Adding the Roof
Drag a Roof into Workplane
Step 62: Creating the Small Chapel Behing the Right Aisle: Step 4 - Adding the Roof
Step 63: Creating the Small Chapel Behing the Right Aisle: Step 5 - Adding the Roof
Step 64: Creating the Small Chapel Behing the Right Aisle: Step 6 - Adding the Roof
Lift the Roof at the height of the Box(at 2.50 at this tutorial)
Step 65: Creating the Small Chapel Behing the Right Aisle: Step 7 - Adding the Roof
Click on both shapes (the Roof and the Box) to choose them and align them using the relative tool (as it's demonstrate on the image)
Step 66: Creating the Small Chapel Behing the Right Aisle: Step 8 - Adding the Semicylinder Part of the Sanctuary
Drag a Cylinder into Workplane
Step 67: Creating the Small Chapel Behing the Right Aisle: Step 9 - Adding the Semicylinder Part of the Sanctuary
Step 68: Creating the Small Chapel Behing the Right Aisle: Step 10 - Adding the Semicylinder Part of the Sanctuary
Step 69: Creating the Small Chapel Behing the Right Aisle: Step 11 - Adding the Semicylinder Part of the Sanctuary
Drag a Cone into Workplane and adjust the length and width to match the scale you have decided.
Step 70: Creating the Small Chapel Behing the Right Aisle: Step 11 - Adding the Semicylinder Part of the Sanctuary
Step 71: Creating the Small Chapel Behing the Right Aisle: Step 12 - Adding the Semicylinder Part of the Sanctuary
Lift the Roof at the height of the Cylinder(at 0.50 at this tutorial)
Step 72: Creating the Small Chapel Behing the Right Aisle: Step 13 - Adding the Semicylinder Part of the Sanctuary
Click on both shapes (the Roof and the Cylinder) to choose them and align them using the relative tool (as it's demonstrate on the image)
Step 73: Creating the Small Chapel Behing the Right Aisle: Step 14 - Adding the Semicylinder Part of the Sanctuary
Click on both shapes (the Roof and the Cylinder) to choose them and group them using the relative tool (as it's demonstrate on the image)
Step 74: Connect the Created Parts: Step 1
Click on both shapes (the Small Chapel and the Cylinder) to choose them and align them using the relative tool (as it's demonstrate on the image)
Step 75: Connect the Created Parts: Step 2
Drag the Cylinder to "stick" it on the Small Chapel so as only the half of it to be visible (the Small Chappel should looks like the one on the image)
Step 76: Creating the Small Chapel Behing the Left Aisle: Step 1
Click on all shapes of the Small Chapel to select them and group them using the relative tool (as it's demonstrate on the image)
Step 77: Creating the Small Chapel Behing the Left Aisle: Step 2
Duplicate the Small Chapel using the relative tool (as it's demonstrate on the image)
Step 78: Connect the Chapels With the Right & Left Aisles: Step 1
Drag the duplicated chapel aside and click on the 1st one and the Right Aisle to select them. Aling them using the relative tool (as it's demonstrate on the image). Do the same for the duplicated chapel and the Left Aisle
Step 79: Connect the Chapels With the Right & Left Aisles: Step 2
Drag the Chapels to "stick" them behind the Right and Left Aisle respectively(as it's demonstrate on the image)
Step 80: Connect the Chapels With the Right & Left Aisles: Step 2
The model should looks like the one on the image
Step 81: Creating the Connector Aisle Between the Nave and the Tower: Step 1
Drag a Box into Workplane
Step 82: Creating the Connector Aisle Between the Nave and the Tower: Step 2
Step 83: Creating the Connector Aisle Between the Nave and the Tower: Step 3
Step 84: Creating the Connector Aisle Between the Nave and the Tower: Step 4 - Adding the Roof
Step 85: Creating the Connector Aisle Between the Nave and the Tower: Step 5 - Adding the Roof
Turn the Roof by 90 degrees
Step 86: Creating the Connector Aisle Between the Nave and the Tower: Step 6 - Adding the Roof
Step 87: Creating the Connector Aisle Between the Nave and the Tower: Step 7 - Adding the Roof
Step 88: Creating the Connector Aisle Between the Nave and the Tower: Step 8 - Adding the Roof
Lift the Roof at the height of the Box (at 2.50 at this tutorial)
Step 89: Creating the Connector Aisle Between the Nave and the Tower: Step 9 - Adding the Roof
Click on both shapes (the Roof and the Box) to choose them, align them and group them using the relative tools.
Step 90: Connect the Created Parts
Drag the Connector Aisle to "stick" it on the appropriate place of the Left Aisle.
Step 91: Creating the Tower: Step 1
Drag a Cylinder into Workplane.
Step 92: Creating the Tower: Step 2
Step 93: Creating the Tower: Step 3
Step 94: Creating the Tower: Step 4 - Adding the Roof
Drag a Cone into the Workplane
Step 95: Creating the Tower: Step 5 - Adding the Roof
Step 96: Creating the Tower: Step 6 - Adding the Roof
Step 97: Creating the Tower: Step 7 - Adding the Roof
Lift the Roof at the height of the Cylinder(at 32.00 at this tutorial)
Step 98: Creating the Tower: Step 8 - Adding the Roof
Click on both shapes (the Roof and the Cylinder) to choose them and align them using the relative tools (as it's demonstrate on the image).
Step 99: Creating the Tower: Step 9 - Adding the Roof
Click on both shapes (the Roof and the Cylinder) to choose them and group them using the relative tools (as it's demonstrate on the image).
Step 100: Creating the Tower: Step 10 - Adding the Roof
Drag the Tower to "stick" it on Connector Aisle.
Step 101: Basilica of Sant'Apollinare in Classe
Your model is finished and should looks like the one on the images.
Step 102: Continuing ...
Complete your model by adding a floor, tiled roofs, doors, windows and stone walls.
Good Luck!!!
Teacher Contest
Teacher Contest
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • Reuse Contest
      Reuse Contest
    2 Discussions
    seamster
    7 weeks ago
    Impressive use of Tinkercad. Very well done! : )
