Battery Organizer
9,871
128
18
About: Jack-of-all trades, master of some. I would probably be much more modest if it wasn't for these delusions of granduer that I suffer from.
I got tired of my batteries roaming wild in my junk drawer and decided to build them a new home.
Each of these designs will make a rack that measures 192 mm x 145 mm (7.5" x 5.75")
All files are also available at https://www.thingiverse.com/thing:3429076
Step 1: Assorted Battery Holder
I originally designed it to have a solid base, but then I reworked it to have a mesh base to cut down on filament use and print time.
The top and bottom are each 5 mm high.
To maximize filament and time efficiency, print the base of your choice, as many spacers(see next step) as you think you will need ( I used 2 D, 1 C, 2AA, 2 AAA, and 2 9V) and then a top to match.
The pre-made assorted battery holder (battery holder mesh base.stl, Battery holder top.stl) will hold:
4 D cell
5 C cell
40 AA
30 AAA
4 9V
8 CR2032 button cell batteries
Step 2: Spacers
These spacers are all 20 mm high. Combined with the top and bottom from the previous step, the holder will be 30 mm high.
Step 3: Make Your Own
In case you have different battery needs, here is an assortment of different sized battery rings separated by size as well as a mesh base.
Feel free to mix and match to suit your needs.
Step 4: Size Specific Racks
Here are a few racks designed for just one size of battery per rack.
The D cell holder (Battery holder D cell only.stl) will hold 20 batteries
The C cell holder (Battery holder C cell only.stl) will hold 35 batteries
Step 5: Reworking the Design to Be More Efficient
In order to make a more efficient print I retooled the rack for the C cell batteries.
The modified files, Battery holder C cell only short top.stl, and Battery holder C cell only short bottom.stl.
Using these files and 5 of the C cell spacers will make a rack that will still hold 35 C cells, but it will take about half of the amount of filament to print and be done in just over half as long.
Organization Contest
    • Stone Concrete and Cement Contest
    • Growing Beyond Earth Maker Contest
    • Planter Challenge
      Planter Challenge
    18 Discussions
    Louis1246
    4 months ago
    I really like this idea and will certainly put it to use. I'm a little confused though. Do I print out the mesh bed separately and next print the battery holder bottom, standoffs and top and set them on the mesh? Also is everything printed at 0% infill? Thanks
    808041
    Question 4 months ago
    WHat kind of 3d printer would you recomend?
    1 answer
    Lorddrake808041
    Answer 4 months ago
    I can not give a fully informed comparison between 3D printers since I have only used the 3D printer that I have, an Ender 3 Pro made by Creality. I have nothing but good things to say about it . Set up was easy, it is very user friendly, a fast learning curve to get it all dialed in. It retails for under $300, so it is a great beginner investment.
    kimtyson
    4 months ago on Step 5
    Nicely organized - however, I cannot download the PDF for this one. 404 on the PDF links.
    Instructables do not return or acknowlege my support request emails. Is this happening to anyone else?
    seamsterkimtyson
    Reply 4 months ago
    This is a known issue that is actively being addressed by the site's engineer team. We're hoping to restore functionality of the download-as-PDF button very soon.
    marcm92
    4 months ago
    The download selection just ends at a cannot find notice! Perhaps you could ask "instructsblrs" to re target the download icon for this.
    Great idea and I'll print off a few for all my rechargeable batteries.
    FredR30
    4 months ago on Introduction
    Just to remind you to cover them afterwards to increase battery life by avoiding discharge
    LeslieGeee
    4 months ago
    Nice idea, thank you for sharing. For those of us who do not have a printer your idea can be worked in wood with hole maker drill bits. If you want to save of the filament you could try attaching a thin piece of MDF or plywood to the bottom of your holders. :)
    As I was looking again at your first picture, PVC pipe can also be used and attached to each other with PVC glue. You can use larger diameter pipe to store multi AA & AAA batteries. I was also thinking if a person has a work room the battery storage can be adapted to hang on a wall so that drawer space is saved. :)
    LorddrakeLeslieGeee
    Reply 4 months ago
    All very good idea. thanks do much for your input.
    In case you want to make a holder out of wood, the dimensions of the batteries I used in the holder are:
    AAA - 10.5mm / 0.41 inches
    AA - 14.5mm / 0.57 inches
    C - 26.2mm / 1.03 inches
    D - 33.2 mm / 1.3 inches
    9v - 26.5mm x 17.5mm / 1.04 x 0.69 inches
    cr2032 - 20mm / .78 inches
    LarryG7
    4 months ago
    You must have a lot of extra time on your hands! Good explanation of how to develop a procedure to make the different size holders. But now you have to remove the batteries from their packaging and put them in the holders.
    LorddrakeLarryG7
    Reply 4 months ago
    not nearly as much free time as I would like LOL. Batteries never seem to stay contained in their boxes once they are opened in my house. Batteries seem to breed in my junk drawer the way wire coat hanger breed in empty closets :)
    LorddrakeAnandM54
    Reply 4 months ago
    Thanks. If you make one please post it in the I made it section
