Be a Romantic Scientist: Distill Your Own Perfume Oil.
189,909
595
174
Introduction: Be a Romantic Scientist: Distill Your Own Perfume Oil.
About: Find me on TikTok, Reddit, Tumblr and Twitter as @KitemanX.
Perfume is often seen as a last-minute gift that requires little thought. But what if you made your own, unique scents?
Step 1: Materials Needed
You will need a vessel to heat water in, a source of heat, gauze or muslin, thread, a delivery tube, a receiving vessel and ice.
You will also need a pretty bottle to store your scent.
For this example, we used a conical flask, a fabric bag of sprigs of lavender plus shredded, a plastic delivery tube and a test-tube in a beaker of cold water. The oil was stored in a film cannister. You may use whatever equipment you can find, at whatever scale you need to produce your scent.
If you are blending oils, you will need a dropper pipette for each raw oil you use.
Step 2: Distillation.
Gently heat the water so that it simmers, rather than boils violently. You need a steady supply of steam passing through the lavender.
Notice how the equipment is arranged so that the steam must pass through the lavender on its way out.
The steam passes along the plastic tube to the test tube, where it condenses on contact ith the ice-cooled glass.
Step 3: Making Your Scent.
The disillate needs to be kept in an air-tight container.
Try a variety of materials to extract the oils. They will not always smell the same after extraction as before, as some oils are easier to distil this way.
Try:
Scented leaves like lavender, mint or thyme.
Flowers - roses or violets are good.
Fruits like citrus or apple peels or pears
"Green" smells, like mosses, or leaves and twigs fresh from the tree, nuts and kernels like almond or a cracked-open peach-stone.
Spices, like cinnamon stick, liquorice root or vanilla pod.
When you have a "library" of scents, try blending them to achieve the affect you want. Make sure you add them to a clean container, and use a separate dropper pipette for each raw oil, otherwise you will mix them in unexpected ways.
We used lavender, orange peel, lemon peel and lime peel, both separately and together in the flask.
Step 4: Using the Scent Safely.
Some scented oils are not suitable for direct application to the skin, possibly causing irritation or allergic reactions.
Your oils should, therefore, be used indirectly. Use them in proprietary oil-warmers, or add a few drops to pieces of cloth and hang them in warm places, like over lamps (not too close to the bulb), on radiators or in front of your car air-vents.
It's tempting to make scented candles from the oil, but there is too much water in it - add water to melted wax and you risk rapid boiling spraying molten wax all over the place.
The Instructables Book Contest
5 People Made This Project!
  • Puzzles Speed Challenge
  • CNC Contest 2020
    CNC Contest 2020
  • Secret Compartment Challenge
174 Discussions
FarisN4
FarisN4
Question 1 year ago on Introduction
I have a question about what the thread and gauze are used for. Also, if the gauze contains the biomass then where does the plastic tubing go in order to collect the steam that passes through it?
Kiteman
Kiteman
Answer 1 year ago
The thread is to turn the gauze into a bag.
This bag contains the biomass, and fits over the end of the rubber bung.
The rubber bung has a hole all the way through it (if you're looking in a lab supply catalogue, look for "drilled bung") - the steam goes up fro the water, through the gauze, through the biomass, and then through the hole in the bung and the tube.
Hope that makes things clearer?
FarisN4
FarisN4
Reply 1 year ago
100% clearer. Thank you, I really appreciate it!
SHOE0007
SHOE0007
3 years ago
Nightshade distillation smelly horrible smell repelant mainly.
SHOE0007
SHOE0007
4 years ago
Here is an actual distiller if you can afford it that works a little better than this. This is a good distiller for normal use if you want to keep it simple.
Kiteman
Kiteman
Reply 4 years ago
Oh, that works well, but they usually run at a couple of hundred pounds/dollars (unless you make a lucky ebay find).
I was keeping it simple for pocket-money scale distilling.
Yajawstin
Yajawstin
Reply 3 years ago
I got the condenser tube (10coil) off eBay China for £6 with free post to uk! :P
Kiteman
Kiteman
Reply 3 years ago
Wow!
SHOE0007
SHOE0007
3 years ago
Estimate 0.5-1% of this ester. So you can get in 250 ml near 0.323 to 0.646 g of methyl butyrate.
SHOE0007
SHOE0007
3 years ago
Here I am distilling a compound at an estimated 0.5% methyl butyrate which smells like pineapples from Great Value Pineapple Naturally Flavoured Drink Mix. Here I can get 0.323 g of methyl butyrate. This compound boils near 100 degrees C.
SHOE0007
SHOE0007
3 years ago
However when boiling at 150 degrees C and the high volatility of Furan-2-ylmethanethiol which smells like roasted coffee. Its high volatility and vapor pressure makes it highly probable (odor) in distilling solution of concentrated coffee.
SHOE0007
SHOE0007
3 years ago
Apparently there are 1000 of organic voilitle compounds including Pyrazine, and other chemicals. The odor is a mistry to me.
SHOE0007
SHOE0007
3 years ago
I have been doing more research and most likely sol at 95 degrees of Octyl acetate ( a natural chemical) that smells like orange is probably added to Orange Tang. However I am not sure. It boils at 200 and the glass is at 350 degrees C so half of that is 175 degrees C. Vapors of it are possible. Especially if the humidity is 80% compared to 20%.
0.06/100+ 0.06 *100 = 0.06% of this ester.
SHOE0007
SHOE0007
3 years ago
Here again I am trying to extract a Java Energy drink MOKA COFFEE through distillation. It been outside for 6 months before distilling.
SHOE0007
SHOE0007
3 years ago
The sugar in the solution is an issue.. but can be easily cleaned with water and solvents (acetone).
lexipainter
lexipainter
4 years ago
This makes no sense and the pictures are not helpful :(
Kiteman
Kiteman
Reply 4 years ago
Which bit in particular is causing an issue?
Edbed
Edbed
5 years ago
This looks great. Do you think it would work on catnip?
