Beautiful Photography Prop on a Budget : Pickle Jar Lamp
298
You can use this glass lamp on your night stand to meditate/relax before bed or as a prop from photo shot.
Theses LED on a string comes in various colors or quality. I have some from the dollar store and from Michael's. The difference is with fancy ones, you might get an additional options : On , timer (1 hour) and off. For dollar store, look at the seasonal like Halloween, Christmas or Valentine and maybe it can be found in the garden section too.
I use the combo of red lights and a red rose but you can do any combo of decoration inside and color of string you want.
Supplies:
  • LED String, battery powered.
  • Glass food container. I used a pickle jar. I prefered this over a Masson Jar as the glass isn't embossed by embellishments
  • A fake flower
  • Some tools of your choice to make a hole in the lid (Punch, dremel, nail & hammer, screwdriver)
  • Paint for the lid. I used a Posca.
  • (optional) Cutter to make work around the flower's sterm
  • (optional) Adhesive remover like GooGone remove the adhesive paper from your jar
Teacher Notes
Step 1: Make a Hole Big Enough to Pass the String of LED
Step 2: Paint the Lid
Step 3: Pass the String of LED Through the Hole, Leaving the Batteries Out.
Step 4: Try to Toss the String in a Pretty Way. Make Sure to Have Your LEDs Turned on at This Step.
Step 5: Make Sure You Are Satisfied With the Result by Turning on and Off the Lights of the Room.
Step 6: This Step Is Only If Used As a Photography Props
Make some lighting tests by having a room / photo studio completely dark or with other small lights in a distance.
Play around with closeness of the jar to the subject or have more than one jar!
Thanks to everyone who looked at this Instructable.
CaroBT Artist
Reuse Contest
This is an entry in the
Reuse Contest
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
