Beautifully Useful Kitchen Handles
22
Current door handles do not take on any personal influence from their users, and very little form the space they actually occupy, and remain physically static over time.
Our handles respond to the individual’s frequency and intensity of use, resulting in a truly unique product each time it is used. The 1000th use will look and feel different to its first use, due to its considered use of materials to affect ephemerality, dynamic form and context-driven interactions.
Supplies:
Upcycled wooden cooking spoon
up cycled stainless steel cake server
2 x Timber backing dimensions 100x100x12 or similar
11 x 30mm galvanised nails
2 x 50mm steel L bracket
1 x steel circular 60mm bracket with 4 attaching holes
hammer
pruning loppers
Teacher Notes
Step 1: Cutting the Spoon
Use the pruning loppers to make a through perpendicular cut across the handle of the wooden spoon.
Step 2: Attach Spoon to Wood Panel
Hammer a nail through the entire of the wooden panel centred all the way through, then gently hammer the scoop end of the spoon onto the nail through the panel.
Step 3: Shaping the Cake Server
Bend the cake server 180 degrees pivoting at the narrowest point on the handle.
Step 4: Attaching the Panel
Slide the wood panel into the gap made by the bent server and attach the circular plate behind the panel but over the server's handle. Use four nails to secure from behind, ensuring the server remains upright.
Step 5: Attaching Supports
Nail in L brackets centrally at the base of the panel's rear side to act as a standing support.
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
