Beebeecraft Instructions on Making Colorful Faceted Bead and Gemstone Bead Bracelet
257
Introduction: Beebeecraft Instructions on Making Colorful Faceted Bead and Gemstone Bead Bracelet
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
Summary: Looking for a homemade bead bracelet design? How about this red and yellow bracelet? The following Beebeecraft tutorial will show you how to make this bracelet.
As you can see from above picture, the colors of this beaded bracelet are very delight and beautiful. At many occasions, wearing the delicate jewelry can add to your personal charm and make yourselves stand out even in crowds. The instructions will guide you into a beautiful beaded bracelet pattern, let us start!
Teacher Notes
Step 1: Jewelry Craft Supplies in Making the Red and Yellow Seed Bead Bracelet:
10mm Round White Cat Eye Beads
6x4mm Faceted Abacus Electroplate Glass Beads Strands
Tibetan Style Alloy Toggle Clasps
4-10mm brass jump rings
Mix Silver Color Iron Eyepins
0.2mm Jewelry string clear Nylon Wire
Step 2: The Beaded Bracelet Making Tutorials
Step 1: add the 10mm cat eye bead to the eyepin and make a loop at the end;
Step 2: thread four 6x4mm red abacus beads to the tiger wire and tighten the wire as the picture;
Step 3: thread 2 yellow crystal glass beads to each end of the tiger wire, cross both ends through the loop of a 10mm cat eye bead; Step 4: continue to add 2 yellow abacus beads to both ends and cross both ends to a 6x4mm red abacus bead;
Step 5: continue to thread beads to make patterns like before to make more beaded patterns, and the length depends on your wrist;
Step 6: add jump rings through the hole of the beads of 2 ends, add the toggle clasp.
Step 3: Final Piece of the Woven Seed Bead Bracelet!
Wow, this red and yellow flower bead bracelet is done! This flower bead bracelet is a popular pattern for homemade friendship bracelets. With different colors of beads, you can create a bright and unique bracelet.
Be the First to Share
    • Fandom Contest
      Fandom Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Backyard Contest
      Backyard Contest
