Beebeecraft Tutorials on How to Make Drop Glass Earrings
Introduction: Beebeecraft Tutorials on How to Make Drop Glass Earrings
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
Summary: In today’s Beebeecraft tutorial, we are going to learn how to make a pair of drop earrings. You will see many glass beads and jade beads in different colors with golden copper wire.
Teacher Notes
Step 1: Materials and Tools Needed:
8x6mm imitation crystal glass beads
8x6mm crystal sun catcher glass beads
8x6mm dark green crystal glass beads
6x4mm mixed color imitation jade beads
12x6mm mixed color drop glass beads
0.3mm golden copper wire jewelry wire
19mm golden earring hooks
Steel DIY jewelry pliers set
Step 2: Instructions on How to Make the Earrings:
1. Use the 0.3mm golden copper wire to thread a 12x6mm drop glass bead. And twist the copper wire and span around the top of the drop bead to cover it.
2. Find the drop glass beads you like to make another twists. You should make sure that the look of drop beads should be symmetrical. They look like the tree branches, aren’t they?
3. Continue the steps of adding mixed color drop glass beads. At the same time, you can add some smaller glass beads to make the earrings more beautiful.
4. On this step, you should thread some small jade beads to make the full shape of your earrings. Don’t forget to combine the golden earring hook with it. After that, you can repeat the steps above to finish the other earring.
Step 3: Finish the Earrings
This is the full look of the drop glass earrings. This pair of earrings look very elegant because of the clear and brilliant glass beads and jade beads. If you are also interested in this earrings, don’t hesitate to try by yourself! Welcome to show your designs with us! Welcome to find more jewelry making supplies on Beebeecraft!
Be the First to Share
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    • Paper Contest
      Paper Contest
