Beebeecraft Tutorials on How to Make Easy Safety Pin Bracelet
137
4
Introduction: Beebeecraft Tutorials on How to Make Easy Safety Pin Bracelet
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
Summary: Have you got ideas on making safety pin craft? That sounds interesting and creative, right? This Beebeecraft tutorial will tell you how to make pin bracelet easily, hope you will like it and have a nice try!
See the DIY safety pin bracelet, do you wanna have a try? They are made with only pearl beads and safety pins, so it will be quite easy for even a jewelry making beginner to make. Now, follow me to see together~
Teacher Notes
Step 1: The Materials for This Pin Bracelet:
28mm Safety Pins
8mm White Pearlized Glass Round Beads Strand
4~10mm Silver Iron Jump Rings
Bolt Spring Ring Necklace End Clasps
4.0cmx0.7mm Silver-color Iron Eyepins
DIY Scrapbook Paper Adhesive Tapes
Step 2: Make the Single Component of the Bracelet
1st, slide a 8mm white pearl onto an eyepin, cut off the extra part, make a loop at the end;
2nd, tie the adhesive tapes around the eyepins and then cut it off;
3rd, make 6 pins with ashesive tapes and 6 white pearl with eyepins.
Step 3: Finish the Pin Bracelet
1st, connect the components above by the jump rings as the picture shows;
2nd, connect the pin bracelet with a jumpring and a lobster clasp
now the Adhesive Tapes pin bracelet is done;
Step 4: The Final Look of Adhesive Tapes Pin bracelet:
How do you think of the diy safety pin bracelet? As you can see, the materials are quite easy to find and the procedures are also super simple. Do you wanna have a try? And all the materials can be found on Beebeecraft.
Be the First to Share
    • Cardboard Speed Challenge
    • Sculpting Challenge
      Sculpting Challenge
    • Indoor Plants Challenge
