Beebeecraft Tutorials on How to Make a Wrapped Necklace
8
Introduction: Beebeecraft Tutorials on How to Make a Wrapped Necklace
Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs...
Today we are going to learn a basic jewelry craft tutorial on how to make a wrapped necklace with golden aluminum wire and red nuggets pendant. It looks elegant, isn’t it? Let’s get started now!
Teacher Notes
Step 1: Materials and Tools Needed:
1.5mm golden aluminum wire
30x21x6mm red nuggets pendant
4x3mm golden twisted chains
5mm golden jump rings
9mm golden earring spring clasps
steel DIY jewelry pliers set
Step 2: Instructions on How to Make the Necklace:
1. You need to cross the golden aluminum wire and make a loop. You should notice that the shape should be big enough to hold the red pendant. And then, you can make small spiral shapes with the help of round nose pliers.
2. Continue to make bigger loops and don’t mixed them together. Make some adjustments while wrapping so that the pattern of the necklace is pretty.
3. Make the pattern on the other side. You should make sure that the loops are symmetrical.
4. Attach the golden spring clasps and jump rings to the chain and finish the necklace.
Step 3: Finish
The beautiful necklace is made! Welcome to show me your craft ideasand learn more jewelry making supplies on Beebeecraft.
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Warm and Fuzzy Challenge
    • Wearables Contest
      Wearables Contest
