Beebeecraft Tutorials on Making Beautiful Bracelet With Glass Round Beads
212
Introduction: Beebeecraft Tutorials on Making Beautiful Bracelet With Glass Round Beads
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about b…
Today I will show you a new charming bracelet with glass beads making process. Check the steps below and have a nice try if you love it!With beads and strings at hand, you can actually make many patterns for bracelet. This time, I adopted the woven pattern in friendship bracelet in making this bracelet with glass beads. Beaded bracelets are extremely texture and beautiful, especially glass beads. Bracelet with glass beads is always popular in people, and any season is bracelet with glass beads.
Step 1: Jewelry Craft Supplies Needed in Making a Bracelet With Glass Beads
8mm Crystal Glass Beads
4mm Seed Beads
14x8mm Jump Rings
0.4mm Jewelry String
Jewelry Tool Supplies
6mm Crystal Glass Beads
Jewelry Magnetic Claps
Step 2: Instruction of Making Glass Beads Bracelet:
Step 1: make the first part of the bracelet with glass beads
1st, Slide 12 seed beads into the jewelry string then continue to crossly add 1 8mm crystal glass bead and tight; 2nd, slide a 6mm crystal glass beads on both sides separately, then the jewelry string across 5 seed beads.
Step2: finish the ship of the bracelet
1st, repeat the second step in the above steps to make a main beaded chain;
2nd, after entering the appropriate length of the beaded chain, then the jewelry string cross into 12 4mm seed beads;
3rd, attach the one litter jump ring to both ends of the beaded chain;
4th , attach two big jump rings and a link to one end of the chain, then attach a claw clasp to the other end.
Step 3: The Final Jewelry Just Likes This:
This colorful beaded bracelet looks more beautiful on the flower paper and the color of the beads match wonderful. Do you want to own one? It's an easy making idea and I'm sure you can finish making in a short time. If you want to follow this Beebeecraft Tutorial about making glass beaded bracelet, you can use other beads to replace the glass beads. Anyway, this is a good DIY project to learn sliding skills. Worth trying!
Be the First to Share
    • Mason Jar Speed Challenge
    • Pumpkin Challenge
      Pumpkin Challenge
    • Halloween Contest
      Halloween Contest
