Beebeecraft Tutorials on Making Geometric Triangle Necklace
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
Do you like simple and stylish necklace? Do you want to make one by yourself? How about learn to make a necklace with Beebeecraft during leisure time? Beautiful and stylish necklace is a decoration of our daily life. If you like crafting, if you are jewelry making lovers, let's learn to make this necklace with us. Now, let’s see how to make them in detail together.
Teacher Notes
Step 1: Supplies Needed for the Geometric Triangle Necklace:
8mm Crackle Glass Beads Strands
2mm Black Seed Beads
20x2.5mm Golden Transparent Glass Bugle Beads
Silver Brass Jump Rings
Silver Tone Alloy Lobster Claw Clasps
0.2mm Transparent Fishing Thread Nylon Wire
Steel DIY Jewelry Plier Sets
Step 2: Make the First Part of the Bracelet
1st, cut off a piece of 0.2mm jewelry wire, string the black seed beads into a small circle;
2nd, let the beaded black seed beads circle in the center of the bottom of one bugle beads(as shown in the picture);
3rd, connect 3 bugle beads onto the wire to a triangle shape;
4th, string the crackle glass beads on top of the triangle, and continue to string one small circle of black seed beads on the top of the crackle glass beads.
Step 3: Finish the Triangle Necklace
1st, continue with the step 2 and connect the triangles together until the length of the jewelry reaches the appropriate necklace length;
2nd, use the jump ring and lobster claw clasps to make a buckle for your necklace.
Step 4: Now, This Triangle Necklace Have Been Finished:
After seeing the Beebeecraft tutorials, do you also want to try the simple necklace? If yes, you are supposed to gather the materials, and all the materials can be found on Beebeecraft, then follow this tutorial to make your own one.
Be the First to Share
    • Art Skills Challenge
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
