Beer Bread
3,936
48
22
About: Michael's Test Kitchen - FOOD - SUGAR - RECIPES
Beer Bread is one of the quickest bread recipes out there, with a distinct flavor and an awesome moist texture.
Find this recipe on my baking blog and on my NEW YouTube Channel !
Beer has rising agent in it already, but most store-bought beer will not have enough of it to make the bread rise; for this, most beer bread recipes include baking powder, which reacts with the beer to lets the bread rise and develop air pockets. Because of this process, Beer Bread is certainly a 'quick bread' - the recipe consists of mixing the dry ingredients together, then mixing in the melted butter & beer, then baking right away. There are no rising times or kneading.
Another interesting thing about Beer Bread is that the flavor depends on the type of beer that you use. Darker beer will result in a bread with more intense flavor, and pale beer lends a lighter flavor. For Beer Bread in general, it has been recommended to use pale beer, but you can experiment with whatever type of beer you want.
While researching rising agents in Biscuits, I found that the best method is to use a 1:3 ratio of baking soda and cream of tartar instead of using straight baking powder. This was because is yielded a stronger rising reaction, and took some of the risk away from having a strong baking powder taste in your bread.
So instead of the Tablespoon of baking powder usually called for in Beer Bread recipes, I decided to instead use 2 teaspoons of cream of tartar, and 1 teaspoon of baking soda. The texture ended up just as good as it had with the baking powder, but the strong baking powder taste I was getting before was mostly gone. As always, let me know if you make this recipe, or if you have your own recipe and method of making beer bread, and comment below with feedback or tips & tricks!
Teacher Notes
Step 1: Ingredients
Ingredients: (makes 1 loaf)
1 (12 oz) can pale beer
3 cups all-purpose flour
2 tsp. Cream of Tartar
1 tsp. Baking Soda
¾ teaspoon salt
⅓ cup butter, melted (divided)
Step 2: Grease & Flour
Preheat oven to 375 degrees F.
Grease and flour a 9x5 inch loaf pan, and knock the excess flour out.
Step 3: Dry Ingredients
Mix the dry ingredients together in a medium bowl.
Step 4: Wet Ingredients
Add the beer and half of the melted butter to the dry ingredients, and stir till combined. (reserve the other half of the melted butter for later)
Step 5: Into the Pan
Pour mixture into the loaf pan, smoothing out the top, then pouring the remaining melted butter evenly over the top.
Step 6: Bake It
Bake for 45+ minutes, until a toothpick inserted into the middle comes out clean.
Step 7: Enjoy!
Serve warm
Organic Cooking Challenge
Be the First to Share
    • Made with Math Contest
    • Candy Challenge
      Candy Challenge
    • Multi-Discipline Contest
    22 Discussions
    KittiCarlisle
    Question 1 year ago
    Do you think I could substitute (and keep all other ingredients the same) ginger beer for the beer? I’m not a beer fan but I wanted to try the recipe.
    Vixyn85KittiCarlisle
    Answer 1 year ago
    You can substitute any carbonated beverage in this recipe, but the density of the bread can change. However, be careful of brightly colored sodas as they will give you a colored bread.(i.e. Red cream soda will make a pink bread.)
    KittiCarlisleVixyn85
    Reply 1 year ago
    Thank you for your response to my question. After receiving the first reply that the beverage have alcohol I decided not to try it because, as you know, ginger beer is non-alcoholic. I just moved on without doing any reshearch. Now I think I’ll give it a go.
    Yes! I'm pretty sure it should work just as well; as long as has alcohol i think. Just know that the bread will borrow the flavor from the beer :)
    ERICOSCAR
    1 year ago
    You say that the owen should be set to 375 degrees celsius !!??
    And then you baked it for 45 minutes
    Something is wrong here, was it not 175 degrees ?
    Wille B. Sweden
    bjm1950ERICOSCAR
    Reply 1 year ago
    Preheat oven to 375 degrees F. I would have thought that is pretty clear!
    C is not mentioned.
    I'm sorry, I forgot to put Fahrenheit after that - 375 degrees F - which would be roughly 190 degrees Celsius
    jannie.lloydERICOSCAR
    Reply 1 year ago
    Nope. He said 375 but didn't specify either F° or C°. If using F° the it's still extremely hot so your 175 (F°) is probably nearer the mark. :)
    I haven't tried this recipe yet - I'd not hear do f Beer Bread, it sounds interesting so I'm going to give it a go.
    Jannie in France
    Mex5150
    1 year ago
    Thought this was going to be about baking bread with the lees from brewing, not disappointed though, I'll just try this version when I'm not racking beer LOL
    ANDRELAS
    1 year ago
    Maybe it would be a good idea to get the beer real cold so the bubbles don't go out as much when you mix it in. Then maybe the soda mixture can be less. Something along those lines.
    MichaelsTestKitchenANDRELAS
    Reply 1 year ago
    Sounds like a good idea; For this recipe i didn't chill the beer, but will certainly try that next time
    Penolopy Bulnick
    1 year ago
    Sounds like a fun recipe! Quick bread sounds like the way to go :) So some probably silly questions: Does the alcohol bake off? Do you know if there are types of beer you cannot use for a bread recipe like this (I don't drink beer so I don't know much about it)?
    jjmcgaffeyPenolopy Bulnick
    Reply 1 year ago
    The alcohol definitely bakes off - I'm allergic to it (technically, intolerant, the way some people are lactose intolerant) and can eat beer bread without a problem. I've always used pale beers - but there's also Guinness bread (which is usually more complicated, but I don't see why it wouldn't work here). I have some old dark beer, I should try it.
    I've also usually seen the recipe say use flat beer - let it sit opened for a while, or even cook it a little (warm it in a saucepan) to get rid of fizz. Now that this recipe doesn't say so, I don't know why...
    yeah, it's pretty fun to make; super quick recipe, as well! Yes, the alcohol will bake off in the oven. I'm honestly not sure what types of beer you CAN'T use - but I would say just to be safe, stick with a lighter or pale beer, unless you want to try something stronger, in which case, the flavor of the beer bread will also be stronger. (I don't drink beer either, so I don't know a whole lot about it either :P )
    Yeah, that would be a cool thing to try! They would definitely work and certainly taste interesting, it would just be whether you prefer your bread to taste like that :D
    dchall8
    1 year ago
    +1 for beer bread. I don't like the bitter flavor from beer so I use blueberry ale. It makes an amazing blueberry flavored bread.
    SavageSydTheKid
    1 year ago
    Technically this recipe is not organic because you would need to use organic butter, organic flour, and organic baking powder. If you include those things in your recipe, it can then be organic. I do like the idea of the beer bread, but to me right now it's just not organic.
    You're right! It's not organic, I didn't make it for the contest, but...it was accepted somehow :P So it probably won't win or anything XD
