Beginner Ukulele
49
Create a ukulele in seven easy steps!
Teacher Notes
Step 1: Cut Cellophane
Cut out the plastic (cellophane) in the opening of the tissue box for ease of strumming.
Step 2: Trace Paper Towel Roll
With a marker, use the paper towel roll to trace a circle on one small side of the box.
Step 3: Cut Hole
Cut around the lines of the traced circle with a craft knife and throw it away.
Step 4: Insert Paper Towel Roll
Insert the paper towel roll two to three inches into the hole on the side of the box.
Step 5: Secure Paper Towel Roll
Secure the paper towel roll to the box by adding a ring of hot glue around the outside of the roll.
Step 6: Add Rubber Bands
Add four rubber bands lengthwise to the box over the oval tissue hole. You may use tape on the bottom of the box to secure the rubber bands. You can use an assortment of rubber band sizes to vary the sounds when strumming.
Step 7: Decorate
Decorate your box and rock on!
Be the First to Share
    • Book Character Costume Challenge
    • Made with Math Contest
    • Cardboard Speed Challenge
