Beginners Wiring Projects: LED Banks
66,318
83
32
Introduction: Beginners Wiring Projects: LED Banks
About: I study engineering at Virginia Tech. Long time instructables fan.
Learn to wire up two sequences of three LEDs to a PC board, mount to a project box (Altiods tin), and control them with the use of a power and variable switch.
Please note that this is a beginner project, and that I am just learning to solder and wire myself.
The wiring here is fairly simple, but it takes some thinking to figure out, especially without an equally confusing diagram...
It's amazing how much I'm getting flamed for such a simple project. I fully acknowledge that it was possible for me to use a bigger battery with a resistor, however I did not have a resistor with the appropriate ohm value at the time for any of the batteries I had present. Not to mention this is a beginner project, and the button cells work fine, even with a sequence of three LEDs. To go even farther, the maximum voltage for the green LEDs is exactly 3v. A 1ohm resistor would be useless here. The maximum voltage for the yellow is slightly less than 3v, but enough that they've been left on for more than a couple days combined, and are doing just fine.
Teacher Notes
Step 1: Materials
The materials required for this project are fairly basic, and most can be bought/obtained from RadioShack and your local hardware store.
Tools:
Needlenose Pliers
Soldering Iron
DREMEL (woo!)
Parts:
Wire - Any scrap will do, just make sure you have enough, it is extremely helpful if you have two colors
PC board - I got mine at RadioShack, they're cheap
Six LEDs - Three one color, and three another. All should be low enough voltage to be powered by 3-4 volts. (two 1.5-ish button cells)
Two switches - One 1-way and another 2-way
Solder
Two 1.5V Button cell batteries - Power
Electrical Tape
Multimeter - Optional, helps test connections
Step 2: Preparing the PC Board
In this step we will be using the PC board, solder, soldering iron, LEDs, and needlenose pliers.
My PC board I got from RadioShack Had this nice little travel circuit that I used to wire one set of my LEDs, while on the other, I manually hooked up the LEDs with wire.
Place one color of the LEDs like you see in the first picture, making sure that you keep the positive (longer) side of the LEDs to one side.
The last LED shown in the sequence is wrong in these pictures, it should be soldered like the others, exactly the same.
Once you have the three LEDs wired in sequence, simply solder a red wire to the positive side, and a green one to the negative. Snip the excess leads on the installed LEDs and start working on the other three, soldering wires to each of the LED leads instead of using the built-in travel circuit.
Simply solder the connection wires to the ends of the LED leads, and secure to the board with bent pieces of solder.
Remember, when soldering, safety is always important.
Step 3: Preparing the Project Box
In this step, we will use an Altiods tin, Dremel, switches, and some tape.
Take a Sharpie, or any type of marker, and mark out approximately where your holes will go. Attach a drill bit to your Dremel, and punch through for the six LEDs. Widen the holes, sometimes considerably, depending on how far off your original estimate was.
The PC board I used fits in the Altiods tin perfectly, and it sort of holds itself in place for you.
Next, repeat the process on the holes for the two switches. These need to be bigger than the LED holes.
Take off the nuts included with the switches, and mount both in the tin.
Now prepare for the wiring, here's where it gets messy!
Step 4: The Wiring
The wiring for this project is pretty simple, but requires knowledge of soldering. The first step will be to solder the two positive leads of the LEDs (marked by the red wires coming out of the PC board) together.
The next step will be to secure wire to your two button cell batteries with electrical tape. DO NOT SOLDER THESE BATTERIES, THEY EXPLODE! Next solder the two negative leads of the LEDs from the board to the two sides of the 3-way switch.
After that, solder the Positive lead of the battery to the power switch, and the negative lead to the middle of the 3-way switch to complete the circuit!
Good luck lighting up dark places!
The Instructables Book Contest
Be the First to Share
    • Tiny Speed Challenge
    • Clocks Contest
      Clocks Contest
    • PCB Design Challenge
    32 Discussions
    koidoug58
    koidoug58
    2 months ago
    Hi I'm going to make a wooden map for my wall and want to put 4 leds lights in 1 in England white/ 1 in Scotland blue/ 1 in Wales red/ 1 in Ireland green / what would I need power wise plus would I need to put in any resistors. Plus can I use 1 switch to turn them on kind regards Dougie.
    uotsey
    uotsey
    10 years ago on Introduction
     I have never done any type of wiring. I have a classroom project based on the nervous system. I would like to make something along the lines of the game "Operation" which tracks the path of the nervous system. Can anyone point me in the correct direction? Thank you!
    pyro man
    pyro man
    11 years ago on Step 1
    wats the dremel for? can i just use 1 3-vlt battery?
    Handsome-Ryan
    Handsome-Ryan
    12 years ago on Introduction
    What does the resistor you soldered in line with the LED's do? Oh wait, you didn't use resistors. lol.
    BlackHatCracker
    BlackHatCracker
    Reply 11 years ago on Introduction
    Well it is self explaining... It lowers the voltage going to said component. Ohms law... R=E/I to find the value of the resistor needed in any project that you are needing.
    Firebert010
    Firebert010
    Reply 12 years ago on Introduction
    That black kid you're molesting in your picture looks scared. LOLROFLMAOBBQ
    cupnoodles2
    cupnoodles2
    11 years ago on Step 2
    just for the next time u coul use the leads of the leds instead of using wire good ible btw
    miqt
    miqt
    11 years ago on Step 3
    hey, thanks for the easy to follow instructable, i appreciate it...the pictures were pretty clear, i have 1 question though, is it possible to hook up 3 led's in the same way you did except without a pc board (just wires soldered onto the leds)? oh and if anyone else knows, i would appreciate an answer...from anyone.
    Gjdj3
    Gjdj3
    Yeah, the pcb just makes it more organized. I normally don't use PCB myself.
    Gjdj3
    Gjdj3
    That's really cool, but I think you used a bit too much PC board. It could have easily been done with less. But otherwise, great job! That looks like a good way to learn. 5/5 stars.
    Firebert010
    Firebert010
    Please provide some sort of explanation as to why that link was posted here... I understand the relevance to LEDs, but it was unnecessary.
    HillBilly Homer
    LSDiodes.com no longer sells LEDs. This part of the site remains only so that people can look up product specifications. You will not be able to purchase anything. very nice project and Instructable
    Firebert010
    Firebert010
    Thanks. I haven't bought from them in a while anyway, I prefer BestHongKong.
    timberman
    timberman
    i need help, want to make a sign with 50 maby 60 led's where can i go? i am a total beginner at this. bty your project was very helpful.
    Firebert010
    Firebert010
    Well, if you're a beginner with LEDs, I don't suggest starting a project that uses 50 LEDs. Chances are you'll have 20 or so soldered in to your board, and you'll fry one and there'll be this unlit LED right in the middle of your board. I suggest building a couple smaller projects such as this one first so you can get the feel for soldering these. If you do wish to continue regardless, two websites I use are LSDiodes.com and Besthongkong.com. You can buy bulk LEDs there for pretty cheap.
    Darkshot
    Darkshot
    cool man i luv the idea and totally wanna do this project but two q's 1) why the PC board? 2) why a 1 way switch then a 2 way switch? get back ASAP please
    Firebert010
    Firebert010
    Why not? Easier mounting.
    2) why a one way switch then a 2 way switch?
    I'm not quite sure what you mean here, but the one-way switch controls the power supply, (on/off switch) and the two-way switch controls which color LEDs you want to light up.
    Using two two-way switches would be pointless, because half of one of them wouldn't be used at all. I can't use two one-way switches because I wouldn't be able to switch power between the LED banks, which was my goal.
    Darkshot
    Darkshot
    mispelling is because im typing w/ 1 arm...others in a cast....long LONGG story
