Bench With Storage
487
20
Introduction: Bench With Storage
About: I love to build DIY wood projects.
We needed a bench for our house but I wanted to use the space efficiently. So I built a simple Bench with Storage. This bench has drawers that sit on the floor but slide out very easily. These storage boxes are big and store a lot of stuff. Free plans are available at TheDIYPlan
You also might be interested in the corner storage bench that I’ve built previously.
Supplies:
• 4'x4' - 1/2" Plywood (x1)
• 2x4x8' (x4)
• 1x12x8' (x1)
• 1x8x6' (x2)
1 1/4" Pocket hole screws
2 1/2" Pocket Hole Screws
1 5/8" Wood Screws
Wood Glue
1 1/4" Brad Nails
Tools for this project
Drill
Tape Measure
1 3/4" Hole Saw Bit
Sander
• Jig Saw
Miter Saw
Table Saw
Kreg Jig
Pipe Clamps
Teacher Notes
Step 1: Cut Boards for Top of the Bench
First cut two pieces of 2x4 to 67” in length and two pieces to 11 1/4". Then using a Table Saw, rip off ¼” on both sides of the 2x4s pieces to eliminate round edges. Since 2x4s come with rounded edges and 1x12s come with straight edges we need to cut off rounded edges on the 2x4s for the boards to match perfectly. See picture of 2x4s with cut rounded edges. Than cut 1x12 to 64” long. Sand the boards before attaching them together. It makes things easier later on.
Step 2: Drill Pocket Holes
Using a Kreg Jig tool, drill pocket holes as shown on the picture. Make sure to set the Kreg Jig correctly to drill pocket holes for 1 1/4" screws on 1x12 board and 2 1/2" Pocket Hole Screws on 2x4 boards.
Step 3: Assemble Top of the Bench
Apply Wood Glue to all the seams and Clamp the boards together before using screws. This will prevent the board from shifting and creating unwanted misalignment while screwing in the boards.
Step 4: Cut Leg Pieces
Next cut four pieces of 2x4 to 14 1/2" in length and two pieces of 1x12 to 14 1/2". Then drill pocket holes as shown on the picture.
Step 5: Assemble and Attach Legs to Bench
Assemble the two legs using screws and Wood Glue. Then attach the legs to the top section of the bench.
Step 6: Attach Back Support
Cut one 2x4 piece to 60” in length and attach it to the back side of the bench 2” from the ground.
Step 7: Attach Middle Support
Next cut 2x4s for middle supports as shown on a picture. Place a mark exactly in the middle of the bench and then assemble using screws and Wood Glue. You're done with the bench, next step is to work on the boxes.
Step 8: Cut Plywood for Storage Boxes
Now we’ll work on the two boxes that go under the bench. Cut ½” plywood for the bottom, back and sides as shown on the picture. Since there are two boxes, cut two of each board.
Step 9: Assemble the Boxes
Assemble the boxes using Wood Glue and 1 1/4" Brad Nails using Nail Gun.
Step 10: Attach Box Supports
Both boxes will sit on two 2x4s that are 11" long. Attach these 2x4 using 1 5/8" Wood Screws.
Step 11: Cut and Drill Holes for Front Cover of Boxes
Take 1x8 and cut two pieces to 28" in length. One of the boards will be trimmed to 6 1/4" in width. Drill pocket holes on the smaller board. Using a 1 3/4" Hole Saw Bit, drill two holes to provided dimensions. Then with jig saw cut out between the two holes connecting them together. Connect both boards together using 1 1/4" Pocket hole screws.
Step 12: Attach Front Cover to the Boxes
Now attach the front boards to the box using Wood Glue and Nail Gun. If you choose not to use Brad Nails on the front board, than you'll need to drill pocket holes on plywood in step 8.
Step 13: Stain and Paint
Apply wood conditioner, stain and paint. You're done with DIY bench with storage!
Furniture Contest
Furniture Contest
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Wearables Contest
      Wearables Contest
    jessyratfink
    jessyratfink
    5 days ago
    Lovely and simple! I may need one of these for my entryway :D
