Bendy Fabric Postcard - Update: Success!
12,747
64
30
About: I like to make things for the internets. I also sell a pretty cool calendar at supamoto.co. You'll like it.
There's really no reason to send a postcard made of fabric and wire, but why the hell not? You can keep changing the shape of it and keep putting it back to the original rectangular shape. And of course you can mail the thing and your friends have a laugh when it shows up in their mailbox.
Step 1: Inkjet Print Onto Canvas
Print out the addresses and a bounding cut line using the inkjet printing on fabric technique.
Step 2: Cut and Peel
Scissors and fingers, but not at the same time.
Step 3: Cut and Shape Armature Wire
I used 1/16" armature wire for this. Get this stuff if you can because wire from a clothes hanger will be absolutely useless for this.
Cut it and shape it into a wacky rectangle shape.
Step 4: Seal It Up
Cut some Stitch Witchery and place it between the fabric and itself as you fold the edges over.
Now iron it all together.
Step 5: Seal the Corners
Those corners can fray and create some problems. Get some clear nail gloss or nail protector or whatever else your girlfriend will let you use and paint them.
Step 6: Get Bent
Might as well play around with it a bit. The armature wire allows the "card" to hold its shape brilliantly.
Step 7: Mail It Off
Here's the real postcard I made for my friends near Atlanta. I put a 39 cent stamp on it along with some glue for good measure and dropped it off in the mailbox yesterday morning. With luck, it should be there by the weekend.
Step 8: Success! It Makes It
There it is in what is obviously Georgia. Can't deny that, eh?
    • Sensors Contest
      Sensors Contest
    • Sew Tough Challenge
      Sew Tough Challenge
    • Beauty Tips Contest
      Beauty Tips Contest
    30 Discussions
    kelle
    12 years ago on Introduction
    way cool, unfortunately we don't have freezer paper here in Europe but luckily I hade a can of repositionable spray glue at hand. That works too when you glue it to cardstock paper.
    HurdyGurdyMan
    I repeated this, I didnt have any wire so I used some solder and used hot glue to put everything together and seal the corners so it looks good and the corners dont fray. Spare copper wire does the trick too.
    Eddbot
    maybe if you used tiny springs instead of wire it would snap back to it's regular shape, but you would have to wrap the springs with some thing so they don't get tangled up
    joejoerowley
    12 years ago
    What about EL wire rapped around the armature wire. That would be cool. You slip in a CR2032 to power it up.
    naught101
    12 years ago
    cool. I can see a problem if you bend and unbend the wire too much it will get stressed and eventually break. perhaps another cool idea (with a slightly different aim in mind) would be to use spring wire? also, why make it rectangle? you could make it any shape really (although internal corners will leave gaps in the bits you fold over). I reckon a random trapezoid would look pretty cool.
    jleemeronaught101
    Reply 12 years ago
    It's armature wire, it's made to bend a lot without breaking, this is the stuff they use to make armatures for clay figures used in claymation.
    royalesteljleemero
    Reply 12 years ago
    Yeah, it's just aluminum wire. You can also use floral wire just fine for armature wire. The copper is great stuff.
    Bob Moore
    12 years ago on Step 8
    wow luv it - hope to replicate soon - also glad it worked so well
    skirtmuseum
    wow, the post office really will deliver anything. nice.
    jongscx
    12 years ago
    you can also use electrical-fence wire. It's cheap and really pliable, unfortunately, it comes in 25ft sections at least.
    zachninme
    12 years ago
    Glad to see it made it! What will your next postcard be???
    fungus amunguszachninme
    Reply 12 years ago
    Two more have already been sent and received. Both need more pics before they're ready to be published.
    zachninme
    Awesome! Glad to see it worked!
    zachninme
    12 years ago
    I can tell where you picked out the rectangles from to mask the address in PS. Right below the state. The yellowish-shadow gives it away.
    rachel
    12 years ago on Step 5
    There's also stuff called Fray Check which does exactly what you want here, only without getting all stiff. It's available in any fabric store. Maybe your girlfriend will buy some and you can borrow it.
    saites2001
    12 years ago
    Finally, a reasonable use for inkjet printing on fabric. Great job, and very cool!
    zachninmesaites2001
    Reply 12 years ago
    Agreed! Before this, that seemed so useless, unless you were making a scrabble quilt or something ...
    arez81
    12 years ago
    How do you get the postage to stay affixed?? I mean it would fall off eventually. Maybe silcone glue perhaps...
    fungus amungusarez81
    Reply 12 years ago
    I used some Krazy Glue Craft. I haven't gotten it mailed it back to me yet, so hopefully it's already out of the state by now. Does a package need its postage once it's already off and running? I wonder.
