Introduction: Ben's Speaker
hello
this project is a fix of 2 old speakers that i deciedd to combine in to one
i started bt making 2 frames form wood and steal angels and went and printed the subs quarter diameter for getting the right dimension on the wood frame
i made chassis for the 2 subs and i did it with a disk cuter
next step will be to connect the 2 new 8ohm twitter i got from Amazon
by soldering them together.
Step 1:
Step 2:
Step 3:
this is a sticky part when I make the slots for the amazon twitter with the old slots that were on the old speaker
after this will be finished I will make the frame and combine it to the subs cube
and then weld the cables check the sound and glue all the outside counter
Step 4:
this is the step when i connect the amazon twitters
Step 5:
starting to see the end of the project
its well connected . now i need to sound check it and the make the final stage of the outer contour
Step 6:
this palawina wood piece will be the cover for the speaker
by the way didn't made a sound check but it will happen
Woodworking Contest
