Bic Pen Bow & Arrow
Introduction: Bic Pen Bow & Arrow
A Bic pen bow & arrow is a good way to waste time at work or school. Be carefull these things really fly and could poke your eye out.
Teacher Notes
Step 1: Materials
Bic Pen
Rubber band
Step 2: Dissemble
Take apart the pen.
Step 3: Reassemble
Poke a hole in the center of the empty tube big enough for the end of the pen to fit.
Step 4: Add Ruber Band
Cut notches on both side of the pen tube to hold the rubber band in place.
Step 5: Fire!
Insert the pen pull back and fire.
1 Person Made This Project!
  • Wearables Contest
    Wearables Contest
  • Coffee Speed Challenge
  • Fix It Contest
    Fix It Contest
284 Discussions
Letixia_123
Letixia_123
3 years ago
This is hopefully going to safe me from boredom
isniperonmw2
isniperonmw2
9 years ago on Step 4
whats that little hair at the bottom of the pic?
kevcube
kevcube
Reply 8 years ago on Step 4
Oh, you know what it is..
jackcade
jackcade
spiltbrains
spiltbrains
Reply 5 years ago on Introduction
i like this idea - however - cutting the hole in the pen can be tricky...how did you do it?
patar77
patar77
6 years ago
You copied my idea
From,
Patar77
momo1998
momo1998
7 years ago on Introduction
in an actuall bow and arrow the arrow doesnt go through the bow
gnawlej
gnawlej
Now this takes me back. We used to make these in middle school; I got busted and served lunch detention for shooting the ink cartridges and getting them stuck in the ceiling tiles.
Phionixflame
Phionixflame
9 years ago on Step 5
its worth making. it shoots pretty far. if you can try to find a pen with out the colored part on the top. that makes it go way faster
Lord Jon Bigglesworth
Reply 8 years ago on Step 5
I think you can rip off the colored part at the top if you pull hard enough (or maybe I just got a defective pen...)
ightmeaki
ightmeaki
Reply 7 years ago on Step 5
the air goes around the top of the pen and then pushes it out an dthne over making it go straiigter so leave it on
jhua1
jhua1
8 years ago on Step 3
It'd be easier just to use a lighter and get the plastic soft on one side and push the cap through, then light the other side and push it all the way through, then get rid of the access plastic and you're good. It'll also hold the cap in place. TA DA
emercado
emercado
8 years ago on Introduction
Ok, so i tried to do this one but when you make the hole it snaps. So i got a kilemetrico pen and cut just under it. use that instead of the one used so you wont have to make the hole large
d3mond00d
d3mond00d
You can add a target-dart for a blowgun into the ink cartridge itself, sharp part facing away. I did that (with 2 rubberbands,not 1) and it stuck in a wooden door at school
d3mond00d
d3mond00d
Use skewers instead of ink cartridges >=).
d3mond00d
d3mond00d
Just a warning, if you use a knife, be careful. I did that and the knife slid off and gave me a cut that I can tell will turn into a scar XD. So, yeah, be careful.
