Big Real Time Clock Using Arduino
About: Passionate Techie ! Robotics | Electronics | Programming - Worked with Arduino, PIC and ARM Controllers
Real-time clock using DS3231 and p10 Display Matrix
This project demonstrates the use of electronics and embedded system with Clock.
Dot-matrix Display or more commonly referred to as Free Running Text is often found in shops as a means of advertising their products, it is practical and flexible in its use that encourages business actors to use it as advertising advice. Now the use of Dot-matrix Display has spread, not just as advertiser media only, as well as prayer schedules, warning boards, queuing machines, etc.
Here, we will give a post about how I made a clock using p10 Matrix Display and DS3231 RTC using Arduino.
Teacher Notes
Step 1: Step 1: ​Hardware and Software Requirements
HARDWARE:
  • Arduino Uno x 1
  • Push button (Keypad) x 4
  • RTC Module (DS3231)
  • P10 Dot-matrix Display
SOFTWARE:
  • Arduino IDE
  • DMD 2 Library / DMD Library
Before that, you need a supporting library that must be installed on Arduino IDE. To download the DMD2 library mentioned above
Step 2: Connections
*Arduino -> RTC MODULE*
  • A4-> SDA
  • A5-> SCL
  • VCC -> 5V
  • GND -> GND
*Arduino -> P10 DMD*
  • D8-> SCK
  • D6-> A
  • D7-> B
  • D11 -> R
  • D13-> CLK
  • D9-> OE
Step 3: The Code
You can find the sample code below.
//Chakra Healing Harmonizer using Arduino
/*Visit the Channel for more interesting projects https://www.youtube.com/channel/UCks-9JSnVb22dlqt...*/
byte dayOfWeek=4;
byte dayOfMonth=1;#include //SPI.h must be included as DMD is written by SPI (the IDE complains otherwise) #include // #include // #include "Wendy3x5.h" #include "Wire.h" #define DS1307_I2C_ADDRESS 0x68int AlarmSetPin = 2; int SnoozePin = 3; int Alarm = 4; int AlarmSet = 0; int Snooze = 0; int a,b; // Convert normal decimal numbers to binary coded decimal byte decToBcd(byte val) { return ( (val/10*16) + (val%10) ); }// Convert binary coded decimal to normal decimal numbers byte bcdToDec(byte val) { return ( (val/16*10) + (val%16) ); }// 1) Sets the date and time on the ds1307 // 2) Starts the clock // 3) Sets hour mode to 24 hour clock// Assumes you're passing in valid numbersvoid setDateDs1307(byte second, // 0-59 byte minute, // 0-59 byte hour, // 1-23 byte dayOfWeek, // 1-7 byte dayOfMonth, // 1-28/29/30/31 byte month, // 1-12 byte year) // 0-99 { Wire.beginTransmission(DS1307_I2C_ADDRESS); Wire.write(0); Wire.write(decToBcd(second)); // 0 to bit 7 starts the clock Wire.write(decToBcd(minute)); Wire.write(decToBcd(hour)); Wire.write(decToBcd(dayOfWeek)); Wire.write(decToBcd(dayOfMonth)); Wire.write(decToBcd(month)); Wire.write(decToBcd(year)); Wire.write(00010000); // sends 0x10 (hex) 00010000 (binary) to control register - turns on square wave Wire.endTransmission(); }// Gets the date and time from the ds1307 void getDateDs1307(byte *second, byte *minute, byte *hour, byte *dayOfWeek, byte *dayOfMonth, byte *month, byte *year) { // Reset the register pointer Wire.beginTransmission(DS1307_I2C_ADDRESS); Wire.write(0); Wire.endTransmission(); Wire.requestFrom(DS1307_I2C_ADDRESS, 7); }//Fire up the DMD library as dmd DMD dmd(1,1);void ScanDMD() { dmd.scanDisplayBySPI(); }void setup() { byte second, minute, hour, dayOfWeek, dayOfMonth, month, year; //initialize TimerOne's interrupt/CPU usage used to scan and refresh the display Timer1.initialize( 5000 ); //period in microseconds to call ScanDMD. Anything longer than 5000 (5ms) and you can see flicker. Timer1.attachInterrupt( ScanDMD ); //attach the Timer1 interrupt to ScanDMD which goes to dmd.scanDisplayBySPI() //clear/init the DMD pixels held in RAM dmd.clearScreen( true ); //true is normal (all pixels off), false is negative (all pixels on) dmd.selectFont(Wendy3x5 ); Wire.begin(); // Change these values to what you want to set your clock to. // You probably only want to set your clock once and then remove // the setDateDs1307 call. second = 0; minute = 35; hour = 11; // use 24-hour time otherwise day/date calculations will be off dayOfWeek = 1; dayOfMonth = 23; month = 3; year = 14; //uncomment the setDateDs1307 call below to set time to intervals above. Remember if you set the time //you need to uncomment the line below again otherwise the sketch will only stay at the time set. //setDateDs1307(second, minute, hour, dayOfWeek, dayOfMonth, month, year); pinMode(AlarmSetPin, INPUT_PULLUP); pinMode(SnoozePin, INPUT_PULLUP); pinMode(Alarm, OUTPUT); digitalWrite(Alarm, LOW); }void drawDay() // shows day of week { byte second, minute, hour, dayOfWeek, dayOfMonth, month, year; getDateDs1307(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year); switch(dayOfWeek) { case 1: dmd.drawString( 1,0, "Sun,", 3, GRAPHICS_NORMAL ); break; case 2: dmd.drawString( 1,0, "Mon,", 3, GRAPHICS_NORMAL ); break; case 3: dmd.drawString( 1,0, "Tue,", 3, GRAPHICS_NORMAL ); break; case 4: dmd.drawString( 1,0, "Wed,", 3, GRAPHICS_NORMAL ); break; case 5: dmd.drawString( 1,0, "Thu,", 3, GRAPHICS_NORMAL ); break; case 6: dmd.drawString( 1,0, "Fri,", 3, GRAPHICS_NORMAL ); break; case 7: dmd.drawString( 1,0, "Sat,", 3, GRAPHICS_NORMAL ); break; } }void drawDate() // shows numerical date { byte second, minute, hour, dayOfWeek, dayOfMonth, month, year; getDateDs1307(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year); switch(dayOfMonth) { case 1: dmd.drawString( 20,0, "01", 2, GRAPHICS_NORMAL ); break; case 2: dmd.drawString( 20,0, "02", 2, GRAPHICS_NORMAL ); break; case 3: dmd.drawString( 20,0, "03", 2, GRAPHICS_NORMAL ); break; case 4: dmd.drawString( 20,0, "04", 2, GRAPHICS_NORMAL ); break; case 5: dmd.drawString( 20,0, "05", 2, GRAPHICS_NORMAL ); break; case 6: dmd.drawString( 20,0, "06", 2, GRAPHICS_NORMAL ); break; case 7: dmd.drawString( 20,0, "07", 2, GRAPHICS_NORMAL ); break; case 8: dmd.drawString( 20,0, "08", 2, GRAPHICS_NORMAL ); break; case 9: dmd.drawString( 20,0, "09", 2, GRAPHICS_NORMAL ); break; case 10: dmd.drawString( 20,0, "10", 2, GRAPHICS_NORMAL ); break; case 11: dmd.drawString( 20,0, "11", 2, GRAPHICS_NORMAL ); break; case 12: dmd.drawString( 20,0, "12", 2, GRAPHICS_NORMAL ); break; case 13: dmd.drawString( 20,0, "13", 2, GRAPHICS_NORMAL ); break; case 14: dmd.drawString( 20,0, "14", 2, GRAPHICS_NORMAL ); break; case 15: dmd.drawString( 20,0, "15", 2, GRAPHICS_NORMAL ); break; case 16: dmd.drawString( 20,0, "16", 2, GRAPHICS_NORMAL ); break; case 17: dmd.drawString( 20,0, "17", 2, GRAPHICS_NORMAL ); break; case 18: dmd.drawString( 20,0, "18", 2, GRAPHICS_NORMAL ); break; case 19: dmd.drawString( 20,0, "19", 2, GRAPHICS_NORMAL ); break; case 20: dmd.drawString( 20,0, "20", 2, GRAPHICS_NORMAL ); break; case 21: dmd.drawString( 20,0, "21", 2, GRAPHICS_NORMAL ); break; case 22: dmd.drawString( 20,0, "22", 2, GRAPHICS_NORMAL ); break; case 23: dmd.drawString( 20,0, "23", 2, GRAPHICS_NORMAL ); break; case 24: dmd.drawString( 20,0, "24", 2, GRAPHICS_NORMAL ); break; case 25: dmd.drawString( 20,0, "25", 2, GRAPHICS_NORMAL ); break; case 26: dmd.drawString( 20,0, "26", 2, GRAPHICS_NORMAL ); break; case 27: dmd.drawString( 20,0, "27", 2, GRAPHICS_NORMAL ); break; case 28: dmd.drawString( 20,0, "28", 2, GRAPHICS_NORMAL ); break; case 29: dmd.drawString( 20,0, "29", 2, GRAPHICS_NORMAL ); break; case 30: dmd.drawString( 20,0, "30", 2, GRAPHICS_NORMAL ); break; case 31: dmd.drawString( 20,0, "31", 2, GRAPHICS_NORMAL ); break; } }void drawHour() // draws the hour hand { byte second, minute, hour, dayOfWeek, dayOfMonth, month, year; getDateDs1307(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year); if (hour>12) //Remove this if command for 24 hour time { hour=hour-12; // This is a 12 hour Clock } switch(hour) { case 1: dmd.drawString( 0,0, "01", 2, GRAPHICS_NORMAL ); break; case 2: dmd.drawString( 0,0, "02", 2, GRAPHICS_NORMAL ); break; case 3: dmd.drawString( 0,0, "03", 2, GRAPHICS_NORMAL ); break; case 4: dmd.drawString( 0,0, "04", 2, GRAPHICS_NORMAL ); break; case 5: dmd.drawString( 0,0, "05", 2, GRAPHICS_NORMAL ); break; case 6: dmd.drawString( 0,0, "06", 2, GRAPHICS_NORMAL ); break; case 7: dmd.drawString( 0,0, "07", 2, GRAPHICS_NORMAL ); break; case 8: dmd.drawString( 0,0, "08", 2, GRAPHICS_NORMAL ); break; case 9: dmd.drawString( 0,0, "09", 2, GRAPHICS_NORMAL ); break; case 10: dmd.drawString( 0,0, "10", 2, GRAPHICS_NORMAL ); break; case 11: dmd.drawString( 0,0, "11", 2, GRAPHICS_NORMAL ); break; case 12: dmd.drawString( 0,0, "12", 2, GRAPHICS_NORMAL ); break; case 13: dmd.drawString( 0,0, "13", 2, GRAPHICS_NORMAL ); break; case 14: dmd.drawString( 0,0, "14", 2, GRAPHICS_NORMAL ); break; case 15: dmd.drawString( 0,0, "15", 2, GRAPHICS_NORMAL ); break; case 16: dmd.drawString( 0,0, "16", 2, GRAPHICS_NORMAL ); break; case 17: dmd.drawString( 0,0, "17", 2, GRAPHICS_NORMAL ); break; case 18: dmd.drawString( 0,0, "18", 2, GRAPHICS_NORMAL ); break; case 19: dmd.drawString( 0,0, "19", 2, GRAPHICS_NORMAL ); break; case 20: dmd.drawString( 0,0, "20", 2, GRAPHICS_NORMAL ); break; case 21: dmd.drawString( 0,0, "21", 2, GRAPHICS_NORMAL ); break; case 22: dmd.drawString( 0,0, "22", 2, GRAPHICS_NORMAL ); break; case 23: dmd.drawString( 0,0, "23", 2, GRAPHICS_NORMAL ); break; case 24: dmd.drawString( 0,0, "24", 2, GRAPHICS_NORMAL ); break; } }void drawMinute() { byte second, minute, hour, dayOfWeek, dayOfMonth, month, year; getDateDs1307(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year); switch(minute) { case 0: dmd.drawString( 12,0, "00", 2, GRAPHICS_NORMAL ); break; case 1: dmd.drawString( 12,0, "01", 2, GRAPHICS_NORMAL ); break; case 2: dmd.drawString( 12,0, "02", 2, GRAPHICS_NORMAL ); break; case 3: dmd.drawString( 12,0, "03", 2, GRAPHICS_NORMAL ); break; case 4: dmd.drawString( 12,0, "04", 2, GRAPHICS_NORMAL ); break; case 5: dmd.drawString( 12,0, "05", 2, GRAPHICS_NORMAL ); break; case 6: dmd.drawString( 12,0, "06", 2, GRAPHICS_NORMAL ); break; case 7: dmd.drawString( 12,0, "07", 2, GRAPHICS_NORMAL ); break; case 8: dmd.drawString( 12,0, "08", 2, GRAPHICS_NORMAL ); break; case 9: dmd.drawString( 12,0, "09", 2, GRAPHICS_NORMAL ); break; case 10: dmd.drawString( 12,0, "10", 2, GRAPHICS_NORMAL ); break; case 11: dmd.drawString( 12,0, "11", 2, GRAPHICS_NORMAL ); break; case 12: dmd.drawString( 12,0, "12", 2, GRAPHICS_NORMAL ); break; case 13: dmd.drawString( 12,0, "13", 2, GRAPHICS_NORMAL ); break; case 14: dmd.drawString( 12,0, "14", 2, GRAPHICS_NORMAL ); break; case 15: dmd.drawString( 12,0, "15", 2, GRAPHICS_NORMAL ); break; case 16: dmd.drawString( 12,0, "16", 2, GRAPHICS_NORMAL ); break; case 17: dmd.drawString( 12,0, "17", 2, GRAPHICS_NORMAL ); break; case 18: dmd.drawString( 12,0, "18", 2, GRAPHICS_NORMAL ); break; case 19: dmd.drawString( 12,0, "19", 2, GRAPHICS_NORMAL ); break; case 20: dmd.drawString( 12,0, "20", 2, GRAPHICS_NORMAL ); break; case 21: dmd.drawString( 12,0, "21", 2, GRAPHICS_NORMAL ); break; case 22: dmd.drawString( 12,0, "22", 2, GRAPHICS_NORMAL ); break; case 23: dmd.drawString( 12,0, "23", 2, GRAPHICS_NORMAL ); break; case 24: dmd.drawString( 12,0, "24", 2, GRAPHICS_NORMAL ); break; case 25: dmd.drawString( 12,0, "25", 2, GRAPHICS_NORMAL ); break; case 26: dmd.drawString( 12,0, "26", 2, GRAPHICS_NORMAL ); break; case 27: dmd.drawString( 12,0, "27", 2, GRAPHICS_NORMAL ); break; case 28: dmd.drawString( 12,0, "28", 2, GRAPHICS_NORMAL ); break; case 29: dmd.drawString( 12,0, "29", 2, GRAPHICS_NORMAL ); break; case 30: dmd.drawString( 12,0, "30", 2, GRAPHICS_NORMAL ); break; case 31: dmd.drawString( 12,0, "31", 2, GRAPHICS_NORMAL ); break; case 32: dmd.drawString( 12,0, "32", 2, GRAPHICS_NORMAL ); break; case 33: dmd.drawString( 12,0, "33", 2, GRAPHICS_NORMAL ); break; case 34: dmd.drawString( 12,0, "34", 2, GRAPHICS_NORMAL ); break; case 35: dmd.drawString( 12,0, "35", 2, GRAPHICS_NORMAL ); break; case 36: dmd.drawString( 12,0, "36", 2, GRAPHICS_NORMAL ); break; case 37: dmd.drawString( 12,0, "37", 2, GRAPHICS_NORMAL ); break; case 38: dmd.drawString( 12,0, "38", 2, GRAPHICS_NORMAL ); break; case 39: dmd.drawString( 12,0, "39", 2, GRAPHICS_NORMAL ); break; case 40: dmd.drawString( 12,0, "40", 2, GRAPHICS_NORMAL ); break; case 41: dmd.drawString( 12,0, "41", 2, GRAPHICS_NORMAL ); break; case 42: dmd.drawString( 12,0, "42", 2, GRAPHICS_NORMAL ); break; case 43: dmd.drawString( 12,0, "43", 2, GRAPHICS_NORMAL ); break; case 44: dmd.drawString( 12,0, "44", 2, GRAPHICS_NORMAL ); break; case 45: dmd.drawString( 12,0, "45", 2, GRAPHICS_NORMAL ); break; case 46: dmd.drawString( 12,0, "46", 2, GRAPHICS_NORMAL ); break; case 47: dmd.drawString( 12,0, "47", 2, GRAPHICS_NORMAL ); break; case 48: dmd.drawString( 12,0, "48", 2, GRAPHICS_NORMAL ); break; case 49: dmd.drawString( 12,0, "49", 2, GRAPHICS_NORMAL ); break; case 50: dmd.drawString( 12,0, "50", 2, GRAPHICS_NORMAL ); break; case 51: dmd.drawString( 12,0, "51", 2, GRAPHICS_NORMAL ); break; case 52: dmd.drawString( 12,0, "52", 2, GRAPHICS_NORMAL ); break; case 53: dmd.drawString( 12,0, "53", 2, GRAPHICS_NORMAL ); break; case 54: dmd.drawString( 12,0, "54", 2, GRAPHICS_NORMAL ); break; case 55: dmd.drawString( 12,0, "55", 2, GRAPHICS_NORMAL ); break; case 56: dmd.drawString( 12,0, "56", 2, GRAPHICS_NORMAL ); break; case 57: dmd.drawString( 12,0, "57", 2, GRAPHICS_NORMAL ); break; case 58: dmd.drawString( 12,0, "58", 2, GRAPHICS_NORMAL ); break; case 59: dmd.drawString( 12,0, "59", 2, GRAPHICS_NORMAL ); break; } }void drawSec() { byte second, minute, hour, dayOfWeek, dayOfMonth, month, year; getDateDs1307(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year); switch(second) { case 0: dmd.drawString( 24,0, "00", 2, GRAPHICS_NORMAL ); break; case 1: dmd.drawString( 24,0, "01", 2, GRAPHICS_NORMAL ); break; case 2: dmd.drawString( 24,0, "02", 2, GRAPHICS_NORMAL ); break; case 3: dmd.drawString( 24,0, "03", 2, GRAPHICS_NORMAL ); break; case 4: dmd.drawString( 24,0, "04", 2, GRAPHICS_NORMAL ); break; case 5: dmd.drawString( 24,0, "05", 2, GRAPHICS_NORMAL ); break; case 6: dmd.drawString( 24,0, "06", 2, GRAPHICS_NORMAL ); break; case 7: dmd.drawString( 24,0, "07", 2, GRAPHICS_NORMAL ); break; case 8: dmd.drawString( 24,0, "08", 2, GRAPHICS_NORMAL ); break; case 9: dmd.drawString( 24,0, "09", 2, GRAPHICS_NORMAL ); break; case 10: dmd.drawString( 24,0, "10", 2, GRAPHICS_NORMAL ); break; case 11: dmd.drawString( 24,0, "11", 2, GRAPHICS_NORMAL ); break; case 12: dmd.drawString( 24,0, "12", 2, GRAPHICS_NORMAL ); break; case 13: dmd.drawString( 24,0, "13", 2, GRAPHICS_NORMAL ); break; case 14: dmd.drawString( 24,0, "14", 2, GRAPHICS_NORMAL ); break; case 15: dmd.drawString( 24,0, "15", 2, GRAPHICS_NORMAL ); break; case 16: dmd.drawString( 24,0, "16", 2, GRAPHICS_NORMAL ); break; case 17: dmd.drawString( 24,0, "17", 2, GRAPHICS_NORMAL ); break; case 18: dmd.drawString( 24,0, "18", 2, GRAPHICS_NORMAL ); break; case 19: dmd.drawString( 24,0, "19", 2, GRAPHICS_NORMAL ); break; case 20: dmd.drawString( 24,0, "20", 2, GRAPHICS_NORMAL ); break; case 21: dmd.drawString( 24,0, "21", 2, GRAPHICS_NORMAL ); break; case 22: dmd.drawString( 24,0, "22", 2, GRAPHICS_NORMAL ); break; case 23: dmd.drawString( 24,0, "23", 2, GRAPHICS_NORMAL ); break; case 24: dmd.drawString( 24,0, "24", 2, GRAPHICS_NORMAL ); break; case 25: dmd.drawString( 24,0, "25", 2, GRAPHICS_NORMAL ); break; case 26: dmd.drawString( 24,0, "26", 2, GRAPHICS_NORMAL ); break; case 27: dmd.drawString( 24,0, "27", 2, GRAPHICS_NORMAL ); break; case 28: dmd.drawString( 24,0, "28", 2, GRAPHICS_NORMAL ); break; case 29: dmd.drawString( 24,0, "29", 2, GRAPHICS_NORMAL ); break; case 30: dmd.drawString( 24,0, "30", 2, GRAPHICS_NORMAL ); break; case 31: dmd.drawString( 24,0, "31", 2, GRAPHICS_NORMAL ); break; case 32: dmd.drawString( 24,0, "32", 2, GRAPHICS_NORMAL ); break; case 33: dmd.drawString( 24,0, "33", 2, GRAPHICS_NORMAL ); break; case 34: dmd.drawString( 24,0, "34", 2, GRAPHICS_NORMAL ); break; case 35: dmd.drawString( 24,0, "35", 2, GRAPHICS_NORMAL ); break; case 36: dmd.drawString( 24,0, "36", 2, GRAPHICS_NORMAL ); break; case 37: dmd.drawString( 24,0, "37", 2, GRAPHICS_NORMAL ); break; case 38: dmd.drawString( 24,0, "38", 2, GRAPHICS_NORMAL ); break; case 39: dmd.drawString( 24,0, "39", 2, GRAPHICS_NORMAL ); break; case 40: dmd.drawString( 24,0, "40", 2, GRAPHICS_NORMAL ); break; case 41: dmd.drawString( 24,0, "41", 2, GRAPHICS_NORMAL ); break; case 42: dmd.drawString( 24,0, "42", 2, GRAPHICS_NORMAL ); break; case 43: dmd.drawString( 24,0, "43", 2, GRAPHICS_NORMAL ); break; case 44: dmd.drawString( 24,0, "44", 2, GRAPHICS_NORMAL ); break; case 45: dmd.drawString( 24,0, "45", 2, GRAPHICS_NORMAL ); break; case 46: dmd.drawString( 24,0, "46", 2, GRAPHICS_NORMAL ); break; case 47: dmd.drawString( 24,0, "47", 2, GRAPHICS_NORMAL ); break; case 48: dmd.drawString( 24,0, "48", 2, GRAPHICS_NORMAL ); break; case 49: dmd.drawString( 24,0, "49", 2, GRAPHICS_NORMAL ); break; case 50: dmd.drawString( 24,0, "50", 2, GRAPHICS_NORMAL ); break; case 51: dmd.drawString( 24,0, "51", 2, GRAPHICS_NORMAL ); break; case 52: dmd.drawString( 24,0, "52", 2, GRAPHICS_NORMAL ); break; case 53: dmd.drawString( 24,0, "53", 2, GRAPHICS_NORMAL ); break; case 54: dmd.drawString( 24,0, "54", 2, GRAPHICS_NORMAL ); break; case 55: dmd.drawString( 24,0, "55", 2, GRAPHICS_NORMAL ); break; case 56: dmd.drawString( 24,0, "56", 2, GRAPHICS_NORMAL ); break; case 57: dmd.drawString( 24,0, "57", 2, GRAPHICS_NORMAL ); break; case 58: dmd.drawString( 24,0, "58", 2, GRAPHICS_NORMAL ); break; case 59: dmd.drawString( 24,0, "59", 2, GRAPHICS_NORMAL ); break; } }void drawCol1() { dmd.drawString( 8,0, ":", 1, GRAPHICS_NORMAL ); }void drawCol2() { dmd.drawString( 20,0, ":", 1, GRAPHICS_NORMAL ); }void runClock() { // drawDay(); // drawDate(); drawHour(); drawCol1(); drawMinute(); drawCol2(); drawSec(); // CheckAlarm();}/*void AlarmSequence() { drawDay(); drawDate(); drawHour(); drawCol(); drawMinute(); digitalWrite(Alarm, HIGH); delay(1000); dmd.clearScreen( true ); digitalWrite(Alarm, LOW); delay(1000); } */ /*void CheckAlarm() { AlarmSet = digitalRead(AlarmSetPin); Snooze = digitalRead(SnoozePin); byte second, minute, hour, dayOfWeek, dayOfMonth, month, year; getDateDs1307(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year);*/ /* Only Trigger Alarm If it is a day listed below. This can be changed by changing the numbers to any of the following: 1 = Sunday 2 = Monday 3 = Tuesday 4 = Wednesday 5 = Thursday 6 = Friday 7 = Saturday */ /* if(dayOfWeek == 2 || dayOfWeek == 3 || dayOfWeek == 4 || dayOfWeek == 5 ||dayOfWeek == 6) { //This is days ALLOWED to ring alarm if(hour == 18 && minute == 05 ) { //Set Time Here (In 24 hour Time) if(AlarmSet == LOW) { //If alarm pin is on Snooze = digitalRead(SnoozePin); while(Snooze == HIGH) { Snooze = digitalRead(SnoozePin); AlarmSequence(); } } } } } */ void loop() { runClock(); }
Step 4: Features
DMD
  • 32 x 16 high brightness Red LEDs (512 LEDs total) with 10mm pitch
  • Supports 5V operation
  • Viewable over 12 meters away
  • Tough plastic frame
  • Onboard Controller IC
  • Arduino compatible library, graphics functions
RTC
  • counts seconds, minutes, hours and year
  • Accuracy: +2ppm to -2ppm for 0ºC to +40ºC, +3.5ppm to -3.5ppm for -40ºC to +85ºC
  • Digital temperature sensor with a ±3ºC accuracy
  • Two Time-of-day alarms
  • Programmable square wave output
  • Register for Aging trim400Khz I2C interface
  • Low power consumption
  • Automatic power failure battery switch circuitry
  • CR2032 battery backup with two to three-year life
Step 5: Working of This Project: Simple Clock
Step 6: Working of This Project: Clock With Settings
Step 7: Conclusion
Give a thumbs up if it really helped you and do follow my channel for interesting projects :)
Share this video if you like.
Happy to have you subscribed: https://www.youtube.com/channel/UCks-9JSnVb22dlqtMgPjrlg/videos
Thanks for reading!
Make it Glow Contest 2018
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
    5 Discussions
    pubudu udara
    4 months ago
    How to change time and date
    Tôi yêup
    7 months ago
    Tôi không nạp được đoạn mã vào arduino, nó báo lỗi
    TonyT165
    7 months ago
    Tôi đã làm nhưng không thành công, nó bị lỗi không add được thư viện vào arduino
    INSTRJAC1
    Question 9 months ago
    Hi, I liked the design of your clock, I would like to do it, where should I connect the Push button (Keypad) x 4?
    Is the program for arduino complete, I have mistakes when I try to test it?
