Bike Repair Stand Using a Pallet
6,084
105
12
Introduction: Bike Repair Stand Using a Pallet
This is how to make your own bike repair stand for under $40.
Supplies:
1. Wood pallet
2. 1 in. threaded floor flange
3. 3/4 x 12 in. steel threaded pipe
4. 1 x 48 in. threaded pipe
5. 1 x 3/4 in. reducer elbow
6. 3/4 in. pipe clamp or pony clamp
7. A handful of screws
8. 5-minute epoxy
9. A short length of 1x2 but it doesn't really matter nearly any dimensions will work
Step 1: Mount Flange
Screw your flange down to the pallet. Mount in the middle of one of the outer boards.
Step 2: Screw Together the Pipe
Assemble this upsidedown L out of the pipe. Make sure to tighten all the pipe as much as possible so your stand will be more secure.
Step 3: Cut Your Board and Drill Seat-post Hole
Cut the 1 x 2 board in two 2.5 in sections. Then clamp them together and drill a hole ( the size will depend on the diameter of your bike's seat-post) through them. Once you've drilled your hole, epoxy one side of you clamp to one piece of wood and do the same with the other.
Step 4: Put the Clamps On
Slide the jockeying part of the clamp on, then screw the outer tightening part on.
Step 5: Put Bike in and Tighten Clamp, Now You're Ready to Rip
Be the First to Share
    • Lighting Challenge
      Lighting Challenge
    • Metalworking Contest
    • Puzzles Speed Challenge
    12 Discussions
    trfcstu
    trfcstu
    Question 1 year ago
    whats the maximum weight it can realistically hold,
    i have a heavy e-bike [28kg] and was wondering if i should use thicker tubing to compensate the weight
    jantiemen
    jantiemen
    1 year ago
    Nice and simple! I like it.
    But 4 screws in the base are not going to hold it when I get angry eh serious with my bike.... Needs bolts through the wood block.
    And I would put a sheet of old plywood on top as a deck. Less trippin'
    And maybe on old magnet on the horizontal pipe to hold the nuts and bolts I take off the bike.
    And.... too many ideas!
    Good job!
    TimF10
    TimF10
    Reply 1 year ago
    I'm thinking an old car rim or a 5 gallon bucket with concrete in it for the base.
    TimF10
    TimF10
    1 year ago
    Very Cool Idea. Reading it I was thinking of taking an old car rim and mounting your pipe floor flange to it. That way it would take up less space.
    If you need to lower the center of gravity, cover the holes in the rim and fill it with concrete. Or you could use a 5 gallon bucket with some concrete in it as the base.
    mikcal100
    mikcal100
    1 year ago
    Wonderful idea. I would put a piece of plywood on the pallet to keep from getting my foot in-between the slats and maybe twisting or worse breaking an ankle. This would put a end to your cycling year. I may modify this to fit into a vice on my workbench and that way take up less room. For going to a race somewhere this work station would be fantastic. I'll bet with a little work and imagination you could put a tool holder on the upright to keep your tools handy
    MurrayThessman
    MurrayThessman
    1 year ago
    Good ideas. On a similar theme, I fitted a tow ball to the pallet and mounted the car bike rack. ( it was a little low though)
    Leegp
    Leegp
    1 year ago
    I like it, but how much does all of those parts cost? Could be more than you pay for a pre made stand.
    instructur
    instructur
    Reply 1 year ago
    Not at all, I payed just under $40 at home depot. Bike stands cost at least $150 if not more.
    pgs070947
    pgs070947
    1 year ago
    Looks good.
    Can you still turn the pedals? (For gear adjustments etc.)
    instructur
    instructur
    Reply 1 year ago
    Yes, but that is because I have clipless on my bike so it is relatively narrow. You might want to measure from the seatpost to the outside of your pedal and use a longer horizontal piece of pipe.
    deltafour
    deltafour
    1 year ago
    LOVE IT! I'm "stealing" your idea.
