Blue Floating Plywood Shelf
About: I'm a mechanical engineer with huge passion for creativity and making a change.
I have made this project at the woodshop because I was bored and I used some of the wood wastes to to make a cool wood product. Floating in shelves are a very cool type of shelves
Teacher Notes
Step 1: What You Need ?
  • A saw to cut wood
  • () plywood
  • Stapler Gun Nail
  • Sandpaper
  • spray paint
Step 2: Cut, Staple , Sandpaper
cut the wood with the given dimensions
4 pieces (00*00)
2 pieces (00*00)
use the sandpaper to make the surfaces smooth
after this use the stapler to join all the parts together
Step 3: Paint
I advise you to use an oil based paint
In my case I used a spray paint, because I only had this type of paint at home ,and WOW it did a good job.
before painting make sure that the surface is smooth
you can use varnish
Step 4: Final Result
***note :I will soon add a video to this project show the painting processes.
As you can see this is how your shelf will look like at the end. you can sure hang it at the wall and it will be too cool. If you have any comment or questions please let me know
Step 5:
    • Indoor Lighting Contest
    • Metal Contest
      Metal Contest
    • Make It Fly Challenge
