Bluetooth Controlled LED Using Arduino Uno
This project is about controlling LED lights using Arduino and a Bluetooth app. I have used Arduino Uno for this project but you can use any Arduino board. Download this source code and upload it to your board before starting the project
Supplies:
Arduino Uno
Bluetooth module HC-06
LED lights
Breadboard
Male to male jumper wires
Teacher Notes
Step 1: Connect Arduino Board and the Breadboard
Connect Arduino's 5v and ground pin to the breadboard using the jumper wires
Step 2: Connect Bluetooth Module and Arduino
Place the HC-06 module on the breadboard. And then do the following connection using the jumper wires
VCC-pin 5v
gnd-gnd pin
Tx-digital pin 0(rx)
Rx-digital pin 1(tx)
Step 3: Make LED Connections
Place the led lights on the breadboard and then give the following connections for the led positive pin.
LED1- pin 3
LED2-pin4
LED3-pin5
connect all the led negative pins to the ground of the breadboard
Step 4: Power Up Arduino
Connect your Arduino board to the pc using the USB cable. you can also use a separate adapter to power up the Arduino. The led in Bluetooth module should turn on, if not check the connections again.
Step 5: Open the App
Open the Bluetooth app and click the Bluetooth icon
Step 6: Connect Arduino and HC-06
Turn on Bluetooth on your phone. Connect with Hc-06 module. The password is usually 1000 or 1234.
Step 7: Enjoy the App
The Bluetooth app shows status as 'connected' if it is connected with the module. If it did not get connect try to reconnect with the module. The led turns on when ON button is pressed and turns off when off button is pressed.
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    2 Discussions
