Bluetooth LED Alarm Clock (7-Segment Display From Trash)
Hello everyone. Welcome back to another instructable.
Last time I have posted an Instructable on how to turn trash into 4-Digit 7-Segment Display
https://www.instructables.com/id/4-Digit-7-Segment...
Today I am going to make a simple alarm clock with the display.
Time can be set via android app using bluetooth .
Teacher Notes
Step 1: Gather the Parts
Here are the parts which you need to make this clock:
The display ( https://www.instructables.com/id/4-Digit-7-Segment... )
(Or you can create one from 7-segment displays)
Arduino UNO (Or nano, it can be made permanent and takes less space)
HC-05 bluetooth module
Amazon.in https://www.amazon.in/REES52-Bluetooth-Transceiver...
Amazon.com https://www.amazon.com/LeaningTech-HC-05-Module-Pa...
Resistors:
1k x3
10k x1
push button
Piezo Buzzer (you can use anything musical for alarm, eg:- greeting card circuit,etc)
9v battery
usb cable and computer for programming
An Android device with bluetooth.
Step 2: The Circuit
The circuit is very simple.
Connect all the parts as shown in above diagram.
The free ends of wire has been marked with the connections of the display.
Step 3: The Code
The code is written using Arduino IDE.
Download the zip , extract, and upload.
The Android app is made using AppInventor2
Install in in the phone.
The .aia file is the source code for the android app.
Watch this video.
Step 4: Final Thoughts
This clock does not uses RTC module.
But it is easy to set the time using bluetooth.
Just set the time and disconnect the device.
Time can be also set using computer. But you need to make the software for the computer or use the serial monitor.
If you have any Doubts leave a comment
Clocks Contest
Clocks Contest
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
