Bluetooth Speaker
24,165
206
9
Introduction: Bluetooth Speaker
About: Hi I'm Linn and on my Youtube Channel I have lots of great videos about building, construction and fun projects. You can also check out my site @ http://darbinorvar.com
This bluetooth speaker is made with solid wood, using maple for the case and white oak for the front and back. It features two rear mount full range speakers, a switch and a light.
To see the full build, and the final result, make sure to watch the video.
Step 1: Mitered Corners
To construct the case I'm using mitered corners because it's such a clean look. They can be a little tricky to get right, and in the past I've used the miter saw, however I found it a lot easier to get accurate cuts using a simple miter jig for the table saw.
Step 2: Front Face
For the front face I'm using 1/4 inch white oak. I marked out the area for the two speakers to go, and drilled the holes on the drill press using a forstner bit.
To round the edges a bit, I'm using a rounder bit and a router, and to make sure the bit had something to ride against, I placed a board with the same cut hole underneath, which worked out great.
Step 3: Finishing the Front
Once the holes were drilled, I marked out where I wanted the switch and the light, and drilled holes where they should go. I then cut the wood to size, sanded it down and stained the oak with a cherry gel stain. I decided to use a stain, because I wanted some nice contrast between the maple surround and the front piece, and the cherry provided a nice color pop.
Step 4: Routing
To create a groove where the front could slip in, I used the router and a 1/4 inch bit. It provided a pretty tight fit, and then I did a dry fit of the entire box to make sure it fit well.
Step 5: Back Blocks
Since the speakers are rear mounted, there's not way to access the electronics from the front. So instead, I needed a way to easily enter from the back. So I cut some wood blocks to size that fit in the back of the speaker, and then drilled holes for some nuts to be glued in. I also drilled holes in a back piece that will line up with the wooden blocks, once everything is glued together.
Step 6: Electronics
For the electronics, I'm using a bluetooth speaker board, a set of 2 inch full range, a female plug, a switch, a 20k ohm resistor, and a 3mm red LED light. I began with connecting the light to the switch, and I wanted the light to be pretty dim, and not light up the whole room once turned on, which is why I used a 20k ohm resistor.
Then I soldered the wires to the speaker, and the speaker wires to the speaker board, in line with the light and the switch.
Parts & Products Used (Affiliate)
Dayton Audio Speakers - https://amzn.to/2OKHxol
Bluetooth Amp - https://amzn.to/2OKHxol
Toggle Switch - https://amzn.to/2OKHxol
Power Supply - https://amzn.to/2OKHxol
Step 7: Adding Components
Next, I wanted to start assembly, but I figured I should finish the front panel first, so I don't accidentally get any shellac on the speakers once they're in.
I drilled a hole for the power plug in one of the sides pieces, then I attached the switch to the front and hot glued the light in from the back. At this point, I tested everything to make sure the light and the switch still worked right before screwing in the speakers.
Step 8: Glue-Up
I then screwed the speakers in from the back, and then I was ready to glue the front and the case together. I tried to minimize glue squeeze out, and only used a careful amount of glue. It's a little tricky to glue everything together just right, especially when placing the front in the groove and lining the miters up right. I also added the blocks in the back loosely to make sure the whole structure was correct, and then clamped it up as it was drying.
Step 9: Closing Up the Box
I hot glued the power plug into the side of the maple. Then I secured the speaker wires into the speaker board and hot glued the board to the interior of the box as well, to keep it in place. At this point, everything that needed to go in the box, was secured, so I could now glue in the back pieces.
Step 10: Feet & Finishing
To give the box a more finished touch, I made some simple feet out of maple, simply by cutting up blocks, and then using a mini plane to plane the sides of the blocks down. To secure to the bottom of the box, I just used some yellow glue and added some weights.
For a finish I first added shellac to the box, and then finished with some beeswax polish.
Step 11: Conclusion - Watch the Video
For a much better perspective of the build, and to see the final speaker in use, make sure to check out the video.
Be the First to Share
    • Mason Jar Speed Challenge
    • Bikes Challenge
      Bikes Challenge
    • Remix Contest
      Remix Contest
    9 Discussions
    EdM63
    EdM63
    5 months ago
    It's a wonderful instructable, I bought the speaker board using your affiliate link, and I'm in the process of using it to restore an old tube radio.
    ChrisPhelps
    ChrisPhelps
    Question 11 months ago on Introduction
    Hello, i was just wondering what the dimensions of the wooden pieces are?
    onegoner
    onegoner
    Question 1 year ago
    You really have a real polished look with your devices that you make. As a novice and I'm pretty unsure of what anything is on these boards, can you do a tutorial on any of the other boards from arylic? Also, are you available to do tutorial requests?
    nandine.ganzorig
    nandine.ganzorig
    1 year ago
    I love this speaker. I am currently analysing products for research purposes and I analysed this one. Could I just ask to what power source is this speaker connected to? Is it a mains power outlet?
    chefahn
    chefahn
    Tip 1 year ago on Introduction
    Looks stunning!!
    Just one little tip:
    If you pay more attention to the grain when cutting the mitres, you can have the grain wrap around the edges on 3 out of the 4 corners (or all 4 if you can be bothered to resaw stock...)
    But it looks beautiful already.
    Willyd57
    Willyd57
    This is an awesome project. And you kicked ass on the miter joints. Well done!
    AllenInks
    AllenInks
    1 year ago
    Beautiful workmanship.
    Some mods I'm thinking about:
    1. Including a battery pack, so the speaker can be used without the power dongle I know the speaker is not as mobile as some small plastic one, but it would be nice to occasionally move it to different areas of the hangar I work in without having to find a power outlet.
    2. Making the power cord less obvious by moving the power inlet plug to the back panel, and including extra wire internally, and soldering male and female 2-pole plug pair into that length of extra wire. With this arrangement, I could still remove the back panel, then stretch out the extra internal length of wire and unplug the internal wire from the internal speaker electronics.
    Thoughts?
    Jhonbaker
    Jhonbaker
    1 year ago
    This is great! Just got this in my Instructable email and was eager to check it out for two reasons - 1. my son and I have embarked on making bluetooth speaker boxes with the Rockler kit, which left me wanting another speaker even though I liked the price. And 2. being familiar with your output I knew that it would be a great project!
