Introduction: Add Bluetooth to Your Old Car-Hifi
Hi everyone!
In this quick ible I'll show you another way to upgrade your old car with just 5$ and less than 30 minutes of work. If you want to check out the last simple upgrade that I made on my car, you have to see my ible "Thermometer - Upgrade Your Old Car".
I'll basically suggest you how to EASILY add the Bluetooth on your old radio (or on a cheap one like mine).
Since I'm an university student I have to study a lot and, specially during the exams period, I have no time to work. But I also hate to ask money to my parents so the only way for me it's to save my money, and to use them wisely.
When I received my 2001 Fiat Panda Young from my brother, I bought this very cheap radio (I think it cost me 25$). It is a quite good radio...I mean I know that it's not the best on the market but for just 25$ it has Aux, USB, SD/MMC card reader, CD reader and various music settings.
Every saturday, when I go out with friends they always want to play their fresh-downloaded songs, so I give them the aux cable to connect their phone to my radio. It's a good solution, but...connect them through the bluetooth wouldn't be a better and a cooler solution?? :P
SO...I simply ordered the cheapest Bluetooth audio receiver on the web, and I tried to obtain the cleanest result possible hiding it in the radio hole. I gave it power connecting it to a 5V portable battery and I also added a ON/OFF button to prevent it from discharging when the bluetooth receiver it's not used.
Step 1: Materials & Tools
MATERIALS:
- Bluetooth audio receiver (5$)
- Portable battery
- ON/OFF button
- Heat shrink tubing
- Old usb (male to female) cable
TOOLS:
- Soldering iron and solder
- Scissors
- Dremel
- Drill bits of different sizes
- Marking pen
Step 2: Understand the Circuit
Since I bought the Bluetooth receiver with the plastic cover (I didn't buy just the circuit), I could have powered it just plugging it to my radio through its usb end, and through the small aux cable that comes with it, but I wanted to mask and hide it, making the result of this small project as clean and natural as possible.
So I decided to power it through a 5V portable battery (which can be bought easily on the web for few dollars), and to add a button to prevent the useless discharging of it.
P.S. I opted for the second possibility also because, due to the cheap radio itself, when I power the bluetooth audio receiver through the radio, it makes a loud and annoying sound that makes me go crazy!! :O If anyone knows the reason, I would be grateful to understand it.
Step 3: Solder Wires to the Button and Modify the USB Cable
In this step we just have to solder two wires to the button, and to modify the usb cable.
I cut the usb cable into two parts, than I resoldered the negative wires together, and I added two longer wires (blue and blue/white) to the existing positive-red ones. I insulated all with heat shrink tubing, letting the ends of blue blue/white wires uncovered.
(this will be helpful when we will have to connect them to the button, after installing it under the car lighter).
Now you should have something similar to photo#4.
Before going to the next step, I suggest you to check if everything works out as it should.
So I quickly twisted the wires of the button, I plugged the bluetooth audio receiver into the female usb port of the cable, and I plugged the male usb port of the cable into the portable battery.
As you can see in photo#6, pushing the blue button the small blue LED of the receiver lights up properly.
Step 4: Choose the Button's Place
I choose to put the button under the cigarette lighter so, in order to access there easily, I simply removed the radio from its hole.
I started by removing the radio panel, its frame, and then I simply pull out the radio from the hole. There are no screws here, except of those "metal springs" that keep the radio in place (photo#4).
Step 5: Make the Hole and Insert the Button
I quickly marked the place of the hole with a marking pen, and then I used the dremel to make it.
I started with a small drill bit, then I enlarged the hole with a bigger one.
In order to make the hole as neat as possible I tested the dimension of the hole, and then I filed it a little with a round file.
When the hole it's perfect you can insert the cable, and then you can screw from behind the panel his nut.
CAUTION: Make sure to wrap the exposed ends of the wires with a small piece of electrical tape, to avoid possible contacts with the back of the cigarette lighter.
Step 6: Connect and Hide Everything
Now it's time to join the 4 wires of the button, and to insulate them with two pieces of heat shrink tubing.
Than connect the bluetooth audio receiver to the battery through our modified usb cable, and put everything in the radio hole.
I decided to keep the result as clean as possible without making another hole for the mini-aux cable, so I simply plugged in one end of the mini-aux cable to the receiver, letting the other end pass in the gap under the dash panel (photo#5).
Step 7: Finish!! Show Your Upgraded Radio to Your Family and Friends!!
Well done! With just 5$ we have upgraded an old radio.
NO MORE WIRES!! If my friends want to play their songs, I simply ask them to turn on the bluetooth on their phones, and with just a click of the blue button, the magic it's done!! You can control the music in the range of 10 meters from it (also if you stay out of the car).
NOTE: My Bluetooth audio receiver connects automatically with all the phones I tested, but if your phone asks a code, enter 0000! ;)
MIND THE GAP! When your battery will run out you will not have to remove again the radio! You will just have to pull the battery out from the gap, disconnect from the usb cable, and after recharging it, you can put it again under the radio. (photo#2)
Thank you for reading my Instructable. ;)
Feel free to comment and ask if you need to know something!
manuelmasc
Glovebox Gadget Challenge
