Bmw DISA Valve Unit Rattle Repair Fix Kit Rattling Repair Instruction Guide
673
Rattling noise coming from the DISA valve? SES light lit and getting lean mixture faults. Rough running at idle. DTC codes and a loss in low end torque. Rattling, buzzing or clicking noise from the engine?
Fault codes: lean condition(P1083, P1085), front oxygen sensor lean (P1090, P1092) oxygen sensor slow response (P1087, P1089) and cylinder misfire (P0311-P0316) fuel control mixture lean (bank 2 sensor 1) and p0174 system too lean, showing?
The original plastic Disa valve components wear and often snap causing the symptoms noted above. The pin retaining the flap can also pop out entering the engine!
The likely cause of the faults noted above and most common cause is the weak plastic components within the DISA valve unit vibrating together and wearing causing the flap to operate at the wrong times and eventually leading to destruction of the flap plate. The pieces of this flap can even enter the engine often causing severe engine damage; likewise the metal pin that holds the flap plate in position can vibrate loose and enter the engine.
Fit our improved design billet aluminium flap kit, designed to never fail, save the cost of a replacement DISA valve which will only fail again.
Using our kit the weak components of the DISA valve the flap and crank lever are replaced with our many times stronger billet aluminium parts, retained by our precision machined screw which tightly retains the two components together; eliminating wear and the need for the retaining pin which can enter the engine. Our part is completely redesigned to never fail- OEM clearances are reduced minimising vibrations in the part preventing any future failure.
Our kit also includes a high temperature Viton 75 O-ring to make a good seal between the DISA unit and the manifold eliminating any air leaks.
BMW M54 3.0
BMW Part 11617544805 or 11617502275
Number on DISA Housing:
7502275 or 7544805
E36 1999-2002 Z3 3.0i Coupé
E36 1999-2002 Z3 3.0i Roadster
E39 2000-2003 530i Sedan
E39 2000-2003 530i Touring
E46 1999-2006 330Ci Convertible
E46 1999-2006 330Ci Coupé
E46 1999-2005 330i Sedan
E46 1999-2005 330i Touring
E46 1999-2004 330xi Sedan
E46 1999-2005 330xi Touring
E53 1999-2006 X5 3.0i SUV
E60 2002-2005 530i Sedan
E65 2002-2005 730i Sedan
E66 2002-2004 730Li Sedan
E83 2003-2006 X3 3.0i SUV
E85 2002-2005 Z4 3.0i Roadster
BMW M54 2.2 &2.5
BMW Part 11617544806 or 11617502269
7544806 or 7502269
E36 2000-2002 Z3 2.5i Roadster
E39 2000-2003 525i Touring
E39 2000-2003 525i Sedan
E46 2000-2004 320i Sedan
E46 2000-2006 325Ci Coupe+M56
E46 2000-2006 325Ci Convertible
E46 2000-2005 325i Touring
E46 2000-2005 325i Sedan
E46 1999-2004 325xi Sedan
E46 1999-2005 325xi Touring
E60 2002-2004 525i Sedan
E83 2003-2006 X3 2.5i SUV
E85 2002-2005 Z4 2.5i Roadster
Step 1: Remove From Engine
Please note engine is on bench for demonstration purposes only, the DISA unit can easily be removed from the engine in situe in the vehicle.
Remove 2x screws and 1x electrical connector and remove DISA unit.
Step 2: Remove Metal Pin.
Lever up pin with small flat had screw driver then remove with pliers.
Step 3: Remove Bell Crank Lever.
Lift off cover on base of DISA unit.
Lift off operating arm.
Using pliers pull out the OEM bell crank lever.
Step 4: Replace Flap
Lift out old plastic flap.
Apply grease as illustrated to the new flap.
Insert new flap to DISA frame.
Step 5: Insert New Bell Crank Lever
Grease bell crank lever as shown.
Insert in to metal flap from below as shown.
Step 6: Attach Pivot Screw
Ensure locking washer is fitted on pivot screw just below head.
Add threadlock to the thread on the screw and grease to the end of the screw as illustrated.
Insert screw through bell crank lever and tighten up.
Step 7: Reattach Operating Arm.
Attach operating arm to bell crank lever and fit locking washer. Push locking washer down with pliers to form tight fit.
Reattach cover and test operation of flap with hand, push flap so fully closed, once released the flap should pop back open. If this doesn't happen recheck install.
Step 8: Replace O-ring
Remove OEM O-ring and fit our Viton O-ring.
The Disa unit can now be refitted to the vehicle.
Installation is carried out at installers risk, if unsure please contact us or a professional, X8R Ltd cannot be held responsible for any adverse result of installing this product or any injuries caused by install, if in doubt ask a professional. All images and texts are copyright X8R Ltd 2014.
    • Planter Challenge
      Planter Challenge
    • Beauty Tips Contest
      Beauty Tips Contest
    • Stone Concrete and Cement Contest
