​Bowl for Dogs
37
Introduction: ​Bowl for Dogs
Bowl for dry dog food.
The holes in the bowl are made so that rainwater flows out
Supplies:
3D printer with print area 300x300 mm
Filament PETG
Teacher Notes
Step 1: Create Bowl
I use that settings for print:
  • Nozzle diameter: 0.4
  • Extrusion width: 0.36
  • Layer height: 0.2
  • Top layers: 5
  • Bottom layers: 2
  • Outline/Perimeter shells: 2
  • Use skirt/brim: yes
  • Infil percentage: 35%
  • Support: no
  • Temperature primary extruder: 225 C
  • Temperature heated bed: 70 C
  • Cooling: starting from 3 layer, 50%
  • Speed: 120 mm/s
Step 2: Stakes for Bowl (optional)
The stakes is needed to fix the bowl on the ground.
Dogs like to play with a bowl and then the bowl is hard to find.
Be the First to Share
    • Trash to Treasure Contest
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    Penolopy Bulnick
    Penolopy Bulnick
    16 days ago
    Thanks for sharing your pet food bowl design :)
