Box for Learning English Words
Introduction: Box for Learning English Words
A simple box for a simple word memorization technique.
Teacher Notes
Step 1: Create a Cube
Create a cube with the specified values.And give it shape using scale
Step 2: Delete Face
Use face selection, select face and use Split.
Delete face.
Step 3: Create a Copy
Create a copy, use Ctrl-C. Select face and delete it.
Step 4: Add Thickness
Create a copy mesh_35. Set objects as on a slide and use Add Thickness to all objects
Step 5: Create Cylinder
Use Move Rotate to place a cylinder
Use Scale with value symmetry and Set the form
Step 6: Stitch and Scoop
Select all objects and use Stitch and Scoop, set the value as on the slide
Step 7: 3D Sketch
Use 3D Sketch, choose Text Sketch. Enter a number and draw
To create a separate drawing select Create new profile and add it.
Draw three numbers
Step 8: Fill Polygons
Select profile and use Fill Polygons.
To place it on the side of the box and hide profile.
Step 9: Add Thickness
Use Add Thickness with value 3 to all numbers
Step 10: Delete Profile
Select profiles and delete it
Step 11:
Be the First to Share
    • Cardboard Speed Challenge
    • Sculpting Challenge
      Sculpting Challenge
    • 3D Printed Contest
      3D Printed Contest
    3 Discussions
    aritoni
    aritoni
    8 days ago
    Interesting! What flash cards you are using?
    Penolopy Bulnick
    Penolopy Bulnick
    2 months ago
    Nice box! Did it take a long time to print?
    Alex-Krynytskyi
    Alex-Krynytskyi
    Reply 2 months ago
    In high quality, 10 hours
