Brake Piston Reset Tool #motorbikelifehack
About: Hobbyist in woodworking, metalworking and music. Basic knowledge in electronics.
Replacing your brake pads might be an easy job, if resetting your brake pistons wouldn't be a tough work. Sure, there are tools available for 25$$$ and more. But why not just cutting two threads into your old braking pads?
1. Drill some holes.
2. Cut some threads into those holes.
3. Just use some screws to reset your brake pistons.
4. Be happy how cheap and easy replacing brake pads can be ;)
Teacher Notes
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    2 Discussions
    sidxbike104
    Tip 1 year ago
    hi i use a j clamp.to push the pistons back.for the last 40 years. there are good tools out there that are cheap to buy. will last you a lifetime. as for this pad drilling and threading, you will
    need a drill and a drill bit to thread the ole .if you have the time.i will add mite this is a good hider you can pass it on when you sell the bike.or car.thank for the tip.from john in the uk.
    tytower
    1 year ago
    Thats a brilliant idea
