Build Your Own Death Star Shade
4,981
47
17
Introduction: Build Your Own Death Star Shade
About: Find me on TikTok, Reddit, Tumblr and Twitter as @KitemanX.
UPDATE: the cutting files are now available on the final step!
If you're reading this, you've bought one of my Death Star lampshade kits*, so, firstly: THANK YOU.
To put the shade together, you will need...
  • PVA glue - the thick, gloopy kind is better.
  • Masking tape.
  • Sandpaper and/or a needle file.
  • Somewhere to hang the shade as you make it.
  • A slightly-damp cloth close at hand for glue-covered fingers.
*If you're confused about this, have a look at my shop: LINK
Step 1: The Jig
To keep things lined up, I made a jig.
Tape the base of the jig into the lower plate of the lampshade. Tape both sides, and make sure you don't obstruct any of the slots.
Slide the core of the jig through the base plate, and the upper plate, then lay them on their side.
Lay the equatorial ring over the top of one of the plates.
Step 2: First Ribs
The ribs have small stems to fit into the top and bottom plates. I have designed them to be snug, but plywood is a natural material and can vary in thickness.
Make sure you test-fit each rib before you glue it. If the fit is too tight for your liking, lightly sand or file inside the slots and test again.
Glue along the stems of the first rib, and glue it in place. Glue the second rib opposite the first.
Move on to the next step before the glue is dry.
Step 3: Add More Ribs
Before the glue is dry on the first two ribs, hand the shade up from the top of the jig core.
Twist the equatorial ring into place between the two ribs, adding glue to both sides of the rib, half way up. Add a piece of masking tape to where the ribs and the ring cross.
Add ribs in pairs, opposite each other, making sure the stems of the ribs are flush in the top and bottom plates, and that the equatorial ring crosses all the ribs half way up.
Step 4: Lower Dish Support Rib And
The Big Shooty Dish is held in place by two partial ribs. The lower one is the larger of the two and needs to be set in place before you set the dish on it.
Make sure you glue it into the equatorial ring as well.
Step 5: Falcon Support Rib
The last full rib you set in place will be the one with an extra small stem on the outside, which is going to support the Millennium Falcon.
Personally, I prefer the Falcon orbiting the bottom of the shade, but if you disagree just fit the support rib the other way up.
Step 6: Big Shooty Dish
While the glued ribs are drying, it's time to put the Big Shooty Dish together.
Simply glue and line up the three parts of the dish, then turn it upside down and add a weight of some kind for a few minutes to give a firm joint.
Step 7: Assemble the Falcon
You simply build up the falcon in layers - start by adding the ring to the bottom of the main fuselage and then add the top parts - most pieces simply line up with the others, but the two smallest rectangles need to be lined up by eye.
Place something flat on top of the Falcon, like a coaster, add a little weight and leave the glue to dry.
Step 8: Fitting the Big Shooty Dish
Add a generous amount of glue to the angle of the lower part of the rib, then glue the upper part of the rib in place and add glue to the angled end of that one as well.
Set the dish in place and then do not disturb it until the glue is dry.
Step 9: Fit the Falcon
Add a blob of glue to the stem for the Falcon, and then slot the Falcon onto the stem.
Leave it to dry, and then you are ready to fit the shade.
Step 10: Finishing
When the glue is all dry, remove the masking tape, including that holding the building jig in place.
Fit the shade to your light fitting, add a bulb, and you're set to go!
Remember: this shade has not been tested with a filament bulb - the heat may make the shade warp. Ideally, you should use an LED bulb, but a CFL bulb will suffice.
Step 11: DIY
Obviously I'd rather you bought your parts from me, but if you have access to a laser cutter, and you pinky-swear not to sell them, I've attached a set of the cutting files to this step.
They're created to use with 3mm thick plywood, but feel free to experiment with other materials, and post your images here if you make your own.
Be the First to Share
    • Puzzles Speed Challenge
    • CNC Contest 2020
      CNC Contest 2020
    • Secret Compartment Challenge
    17 Discussions
    MaraCreates
    MaraCreates
    1 year ago
    This is so cool! We are in the process of building a new house (in the architect stage) and my son's room is going to be Star Wars themed and I will definetely be getting one of these for his room. Thank you for sharing your talents and making it possible for me to make something so cool.
    Kiteman
    Kiteman
    Reply 1 year ago
    You're very welcome!
    Kiteman
    Kiteman
    Reply 1 year ago
    Done - see the final step!
    Triphazard
    Triphazard
    1 year ago
    Ok it's a nice product and you show how it goes together, but I believe instructables were meant to be for people to share their creations and methods, no try and profit from it and use instructables as an advertising platform.
    It seems that all you have done is post a link to your etsy page and show a build manual of what you can achieve you buy one of your products...
    This is not in the spirit of instructables...
    Kiteman
    Kiteman
    Reply 1 year ago
    I totally get that, and I invite you to browse the rest of my 265 projects and see that for almost every single one I share the files.
    I actually wrote this instructable well over a year ago, but had it set to "private", and only shared it with people who bought the parts, but I have had a number of requests to see the instructions public, so here they are.
    Triphazard
    Triphazard
    Reply 1 year ago
    Fair enough.
    Kiteman
    Kiteman
    Reply 1 year ago
    The files are now up - remember to post a photo of your build, but please do not sell kits or finished versions of the shade.
    Kiteman
    Kiteman
    Reply 1 year ago
    Actually, I've decided to share the files, but I need to re-draw them into a format that is more user-friendly. Give it a few days, then come back and see...
    mathewt11
    mathewt11
    Reply 1 year ago
    Well said, surprised instructable twitter guy didn't realise this.
    mathewt11
    mathewt11
    1 year ago
    I thought Disney were pretty hot on suing people profiting from people making fan art?
    Kiteman
    Kiteman
    Reply 1 year ago
    Shhhh!
    Actually, I have been selling stuff for several years, and the only time I've had an objection was from Fox TV.
    mathewt11
    mathewt11
    Reply 1 year ago
    that's good know, people do scaremonger about this from what I can see.
    Kiteman
    Kiteman
    Reply 1 year ago
    Thank you!
    Kiteman
    Kiteman
    Reply 1 year ago
    Thank you!
