Button Making With Button Maker
Materials Needed: Button Maker, Silver Shell, White Backing of Button, Circular Plastic Film (clear) that is the size of the button whole, Scissors, Pencil, Paper (of any kind. I used a magazine)
Step 1: Choosing and Cutting Your Image
Once you chose your image (you can print it) trace a circle around the image and cut the circle out. You can use scissors or a cutting utensil of your choice.
Step 2: Putting the Paper Into the Button
Once you have your circle cut out, you are going to place the metal into the base mold on the left. After the metal is placed you are going to put the picture on top of the metal and then place the plastic film over the image. Once you have done so you slide the left base mold over to the right and press down on the lever, not hard but enough so it is pressed all the way. Once you are done pressing, bring the lever back up to the normal position. Insert the button backing into the right backing.
Step 3: You're Done!
Congratulations you have finished making your button. Feel free to make as many as you want. Like, Comment, and Subscribe.
    • Warm and Fuzzy Contest
    • Organization Contest
    • Sweet Treats Challenge
